INCLINED COLUMN DESIGN
nikhil.patelwsm
PostPosted: Tue Oct 15, 2024 4:35 am    Post subject: INCLINED COLUMN DESIGN Reply with quote
RESIDENTIAL BUILDING WITH G+5 FLOOR G AS STILIT PARKING ARCHITECT WANT COENER COLUMN TO BE SHFTED INSIDE BUILDING BY 1.2 M AND MAKE THEM INCLIEND AT 2.1M ABOVE PLINTH FOR CAR MOVEMENT , I HAVE ATTACH ARCH DWG AND SECTION IS IT POSSIBLE TO MAKE COLUMN INCLINED AT 2.1M I.E. (AT LINTEL LVL TO INCINED TILL FIRST FLOOR AND AFTER THAT FLOOR STAIGHT ) PLEASE GIVE US LOAD PATH IS IT POSSIBLE OR NOT
SECTION OF COLUMN.pdf
ELEVATION SUGGESTED BY ME FOR POSSIBILITY WANT TO KNOW CAN THIS BE FISSIBLE
 Filename:  SECTION OF COLUMN.pdf
 Filesize:  148.75 KB
 Downloaded:  966 Time(s)
SECTION OF COLUMN R1.pdf
ELEVATION OF COLUMN
 Filename:  SECTION OF COLUMN R1.pdf
 Filesize:  148.72 KB
 Downloaded:  954 Time(s)
TYPICAL FLOOR PLAN.pdf
TYPICAL FLOOR PLAN
 Filename:  TYPICAL FLOOR PLAN.pdf
 Filesize:  1.13 MB
 Downloaded:  989 Time(s)
GROUND FLOOR PLAN.pdf
GROUND FLOOR PLAN
 Filename:  GROUND FLOOR PLAN.pdf
 Filesize:  1.12 MB
 Downloaded:  956 Time(s)
PostPosted: Wed Oct 16, 2024 3:32 am    Post subject: Reply with quote
Inclined column in this building arrangement shall be avoided  as it may not provide a healthy structural system.
If Architect is very rigid,, he may be convinced,
Still Rigid :-
Eccentricity of system is never lost and upper storeys load on this column will be eccentric.
A) As regards vertical loads - these will be transferred to this column by twin actions :-
1) Through beam acting as cantilever beam
2) As  Inclined member / corbel resisting vertical load tat tip through Thrust force ( much higher than vertical load based on taper angle) ,, PLUS  Tensile force in the beam.
It will be wise that for such structural arrangement,, designer shall design 100% for each action.
B) Horizontal forces due to EQ
Transfer beam shall be heavy,  to be designed for Moments,, Torsions,,  But a x beam at tip of taper must exist tieing various columns and taking care of distribution of Eq forces
STILL I FEEL,  NOT A GOOD STRUCTURAL ARRANGEMENT,, NEEDS TO BE AVOIDED IF POSSIBLE  ,, SO THAT COLUMNS STRAIGHT( TRULY VERTICAL) WITH Cantilever Overhang OUTSIDE.
PostPosted: Wed Oct 16, 2024 3:36 am    Post subject: Reply with quote
FOR BETTER RESISTANCE TO EQ FORCES :-
Please keep Alternate columns truly vertical with Overhang outside,, so that EQ force is fully taken care by truly vertical column s..
I think Architect msy agree.
atul_123
PostPosted: Mon Jan 20, 2025 9:59 am    Post subject: Re: INCLINED COLUMN DESIGN Reply with quote
Dear Nikhilji
kindly refer sketch provided for better understanding of load transfer.
 Filesize:  80.58 KB
 Viewed:  806 Time(s)
