Manik dutt SEFI Member
Posted: Fri Jul 12, 2024 4:50 pm Post subject: MOST USED FORMULAS IN RCC DESIGN |
WHAT ARE THE MOST IMPORTANT FORMULAS FOR DESIGN OF RCC A STRUCTURE IN THE IS CODE.
Posted: Sun Jul 14, 2024 4:41 am Post subject: |
Dear Er,,
All formulas are important and can not distinguish.
Now a days softwares contain all formulas. Even choice of Country Code is also available.
Structural design working is totally software oriented .
But there is need to study books / codes for understanding of the subject. Software modelling also needs to be understood in light of GIGO.
Yes, in Manual Designs era (extinct) ,, Designs were written by hand considering all aspects .
Ladder to success is :-
Prevailing working with software s being performed in design office gives SE good practice in computerized software s working
But simultaneously
Develop yr own Axle work sheets on designs ,, to help to match results of software output with manual ines on Axel .
Many a times due to fault in understanding of str behaviour resuls do not match. If these are abnormally different, need to focus on study. Of str behaviour. This practice leads to perfection.
Most formulas used :- All Engineets know them
Slabs design - Coefficient s given in IS 456
Beams design - Charts given in DP 16
Columns design for Axial load and min eccentricity only
Pu = 0.4FckBD + 0.67 Fy Ast given in IS 456
For columns with moments, refer charts in 456
Formulas for slenderness eccentricity as per IS 456
Some engineers on sefi developed column charts in axel
And even beam tables can be developed using Sinly reinforced and doubly reinforced can be developed.
You can also refer SP 24 of BIS
Beam shear reinf formulas can developed
Posted: Sun Jul 14, 2024 4:45 am Post subject: |
You can also look to book :-
FORMULAS FOR STRESS AND STRAINS BY YOUNG
ALSO REFER BOOK BY OUR RESPECTED SIR ON SEFI
LIMIT STAGE DESIGN OF REINFORCED STRUCTURES BY UH VARYANI AND RADHA JI
FOR WATER TANKS REFER IS 3370 PART 1,2 &4
FOR FOLDED PLATES REFER BOOK BY SIR UH VARYANI SAHEB
atul_123 ...
Posted: Tue Jan 21, 2025 5:25 am Post subject: Re: MOST USED FORMULAS IN RCC DESIGN |
Manik dutt wrote: | WHAT ARE THE MOST IMPORTANT FORMULAS FOR DESIGN OF RCC A STRUCTURE IN THE IS CODE. |
Dear Sefian,
PFA attached file might be useful.
design_of_concrete_structures_68_76.pdf |
3.57 MB |
55 Time(s) |
RCC.pdf |
2.72 MB |
59 Time(s) |
Meera P SEFI Regulars
Posted: Sat Jan 25, 2025 8:30 am Post subject: MOST USED FORMULAS IN RCC DESIGN |
Sir / mam
There is no PFA file attached with this Post as mentioned at the end of the post.
Kindly send the file.
Thanks and regards
meera p.
