kajal.chopra ...
Posted: Wed Dec 24, 2008 8:08 am Post subject: |
Hi Kedar,
Thanks for the reply.
1.Can you kindly explain point 6 b) of your post? That is, the force passing from the column to the slab due to rigid diaphragm action in an intuitive sense?
2. What if the column is very stiff say a basement column of high rise commercial building?
Kajal |
Kedar SEFI Regulars
Posted: Wed Dec 24, 2008 10:04 am Post subject: |
Hi Kajal
Plz note
1.The Column and slab are integrally casted.i.e. they are note separate entity.
2.The horizontal/shear force applied by tendon is shared in proportion with the stiffness of slab/column system.This is obvious.
3.This shear force will cause BM in column due to small displacement
and axial shortening of slab.
Lets consider simple/quick calculation just to demonstrate how shear force is distributed between slab and column
Considering the previously posted example
consider practical sizes of system
the slab thickness = 350 mm
the column ht = 4200 mm
Column size 900mm x 900mm
column grid = 11m x 11m
Shear force =532 kN
1.Axial stiffness of slab(s suffix)
AsE/Ls
=350E
where
As= tributory length across span x thickness
=11000 x 350
2.Horizontal Reaction/shear at the base of column(c suffix) due to unit deformation
12EIc/Lc^3
=8.86E
Total stiffness at joint = 350E+8.86E
=358.86E
The shear resisted by column
=532 x (8.86/358.86)
=13.13 kN
The shear resisted by slab in form of axial compression
=532 x (350/358.86)
=518.87 kN
It can be seen that
slab takes 97.53% of shear
column takes 2.47% of shear
Assumptions are made
wherever necessary.
Kedar |
kajal.chopra ...
Posted: Wed Dec 24, 2008 10:20 am Post subject: |
Thank you so much for the reply.
But it does have an impact when column is very stiff.
Example:
Say the slab is 150mm thick
Column is 1000mm x 1000mm and 3 m long.
Now:
AE/L of slab = 150 E
12 EI / L^3 of column= 12 E (1000x 1000^3/12) / 3000^2 = 37.03E
Shear = 532 KN
Now, shear taken by slab= 532x 150 / 207 = 385
shear taken by Column = 147 KN.
There could be a scenario like this.Right? |
Kedar SEFI Regulars
Posted: Wed Dec 24, 2008 10:38 am Post subject: |
Hi Kajal
The of system you are describing is
is difficult to exist in practice.
Since one would go for regular beam,slab & column system
why it is necessary to provide post tensioned slab for 3m span?
If at all one want that kind of structure just for the sake of it you need to account all forces i.e. shear in column and all.
Same is applicable for other system elements you
proposed.
Kedar |
kajal.chopra ...
Posted: Wed Dec 24, 2008 10:45 am Post subject: |
I mentioned 3m as height of the column.
Axial stiffness of slab = 11,000 x 150 / 11,000 E = 150 E
Note: i assumed column height as 3m instead of 4.2m what you assumed.
This could be a practical system infact? |
Kedar SEFI Regulars
Hi Kajal
Can you plz check calcs
posted by you?
Kedar |
kajal.chopra ...
Posted: Wed Dec 24, 2008 10:48 am Post subject: |
I do not find anything wrong there? |
Kedar SEFI Regulars
Posted: Wed Dec 24, 2008 10:56 am Post subject: |
Hi Kajal
Plz check summation of stiffness
=150E+37.03E
=187.03E
(not 207E)
so other forces will change.
plz correct me if I am wrong.
Kedar |
kajal.chopra ...
Posted: Wed Dec 24, 2008 11:02 am Post subject: |
Ok, right. In that case shear taken by column is: 106 KN.Can it be neglected? |
Kedar SEFI Regulars
Posted: Wed Dec 24, 2008 11:14 am Post subject: |
Hi Kajal
It all depends on your judgement and calcs.
and how you want your structure to preform.
If you feel shear needs to be accounted
you can as simple as that..
Kedar |
