Difference Between Wind And Seismic Forces
abhy_vivek
PostPosted: Wed Aug 17, 2011 6:33 am    Post subject: Difference Between Wind And Seismic Forces Reply with quote
    My colleague Mr. Aravind Ashok has prepared a document titled 'Difference Between Wind And Seismic Forces', which is enclosed herewith. Hope all of you will find it intersting.
To improve this document give suggestions to Aravind or Undersigned Directly
With Regards
Er. Vivek Abhyankar - C.Eng
स्थापत्य तथा वास्तुअभियंता
Mumbai-400053
DIFFERENCE BETWEEN WIND AND SEISMIC FORCES.pdf
 Filename:  DIFFERENCE BETWEEN WIND AND SEISMIC FORCES.pdf
 Filesize:  390.21 KB
 Downloaded:  2497 Time(s)
Thankful People
pradeep_hebbar
PostPosted: Wed Aug 17, 2011 9:16 am    Post subject: Re: Difference Between Wind And Seismic Forces Reply with quote
Dear Er.Vivek,
That was a very nice & useful information!!
Pradeep Hebbar
sakumar79
PostPosted: Wed Aug 17, 2011 3:20 pm    Post subject: Reply with quote
  Very good compilation... Some minor corrections and additional points are there:
Minor Corrections:
1. In point no. 5, "Base shear value" may be corrected as "shear force" or "contribution of base shear value at a floor". Base shear value is constant, the shear force attracted at each floor level is varying.
2. In point no. 9, for wind load, "Wind load doesnt cause torsion in a structure" is not exactly correct. Wind load can cause torsion in a structure depending on the nature of exposed surface and the supporting mechanism. For example, if a hoarding is placed over a beam along its length, there will be torsion induced on the beam.
Additional points:
1. Wind load is designed for full amount of maximum estimated wind force in a specified duration but eq forces design is for a fraction of the estimated eq force
2. Effect of wind load is expected to be within elastic behaviour whereas ductility/plastic behaviour is essential to eq design
Arun
anshugoel
PostPosted: Wed Aug 17, 2011 7:21 pm    Post subject: Reply with quote
sakumar79 wrote:
Minor Corrections:
Additional points:
Arun
The author is pretty much inaccurate on point 20 to 24 for Wind effect.
There was a recent accident where 4 lives were lost due to wind effect (allegedly).
http://articles.cnn.com/2011-08-13/us/indiana.stage.collapse_1_stage-collapse-wind-gust-sugarland?_s=PM:US
I have also frequently experienced that weather guys get it very much wrong - in no time - thunder become severe thunder storm which escalates to Tornado warning with hail and other accompaniments.
This is quite common in the area where I live. So even with the best of technology - like with doppler radar and most advanced data collection instruments in place, weather forecasting goes wrong quite often - Many people die. Another recent example is Joplin, MO where entire community was wiped out.
raveeleo
PostPosted: Fri Aug 19, 2011 8:45 am    Post subject: Re: Difference Between Wind And Seismic Forces Reply with quote
really a very helpful....
convey the same to your friend.. and thank you for Thanks for Sharing...
ravee
rohan_borges
PostPosted: Sat Aug 20, 2011 1:22 pm    Post subject: Correction. Reply with quote
In the document sumbmitted by Mr. Arvind Ashok he says that "amongst
which the seismic force and the wind force are the common ones"
Wind forces are quite common. But earthquake is not very common though it is significant.
     The remaining part of the document is very well presented and quite useful.
Rohan Borges
syedmuzaffer
PostPosted: Mon Aug 22, 2011 6:45 pm    Post subject: Reply with quote
Very nice and informative...
