Analysis of trusses
junvijay
PostPosted: Sat Oct 27, 2012 3:12 pm    Post subject: Analysis of trusses Reply with quote
Dear sir,
Trusses are supposed to take loads at their joints and joints are assumed to be pin connection. But, if loads are not acting at joints and joints have been done using weld connections then how it should be idealized for analysis purpose.
Vijay kumar.
PostPosted: Mon Oct 29, 2012 12:54 am    Post subject: Re: Analysis of trusses Reply with quote
Dear Er Vijay kumar,
Even when the loads are applied in between he joints (usually this will be the case for rafters, where the purlin loads may not be applied at the joints) and the truss will welded, the trusses are designed as in jointed only. The loads not applied at the joints will produce secondary bending, which can be taken into account in the design. For example, the rafter members are designed for combined  AF and BM. Many books show such an example!
If you assume rigid joints and apply loads at the nodes, the results will show predominantly AFs only!
Best wishes.
junvijay wrote:
Dear sir,
Vijay kumar.
