suraj General Sponsor
Posted: Mon Nov 19, 2012 11:19 am Post subject: Siting Tall Buildings Considerations |
Siting Tall Buildings Considerations<xml><o></o>
1 Mater plans generally, do not permit such buildings in congested areas<o></o>
2 Master plans also, do not permit such buildings near air ports<o></o>
3 Master plans also, do not permit such building near ancient structures<o></o>
4 Since, tall buildings may affect easement rights related to existing structures, such buildings should be proposed, only for free areas<o></o>
5 Such free areas may be located at coast or at river banks<o></o>
6 Such structures often, rest on rocks, properties of soil near surface do not concern considerably<o></o>
7 Tall buildings location should allow locating associated carport to avoid congestion by parked cars blocking all streets or road sides<o></o>
8 Such problems have been noticed even in UAE Abu Dhabi & Dubai, where parking had been a menance & still do<o></o>
9 I have seen cars parked on central line of roads, which is not acceptable<o></o>
10 People had no other choice over there & ready to pay fines<o></o>
11 In fact tall buildings should be permitted in quee of tall buildings<o></o>
12 For example, Doha corniche diplomatic enclave got many slender & tall structures in one row, though looking tall building congested area.<o></o>
13 Personally, I do not appreciate such planning, since planning should speak of some objective or philosophy or unity & rythm<o></o>
14 Tall buildings & other such buildings should reflect about culture of that area & unity with harmonious reflecting announcing structure tuning<o></o>
15 Structure should be exposed to produce vistas created by beams & columns elevations, but it has been seen that all such elevations are covered by space frame supported façade in geometrical profile<o></o>
16 With such envelope framing, whole arcade looks monotonous<o></o>
17 It is not understood by engineers, why such structural elevations that speak of city, are concealed to show artificial architecture<o></o>
_________________ Thanks & Warm Regards
Engineering & Arbitration
Posted: Fri Nov 23, 2012 5:08 am Post subject: Town Planning Concept- Scheme |
- Long 20 years back, I worked schematically on my own on a township conceptual scheme, when in those days, promoters were not aware of integrated towns/self contained concepts, though Delhi Master plan had cleared such concepts in principle
- I was unsuccessful to realize this dream into reality
- Current situation is that promoters have haphazardly abused use of land for townships & just for making trillions of profits
- I attach a file just for reference, while more details could be published later
Note I could not attach power point file due to portal denial
Posted: Sun Nov 25, 2012 5:39 am Post subject: Tall/High Rise Township |
Tall/High Rise Township<o></o>
1 Tall buildings do need high profile supporting services & surroundings<o></o>
2 Such buildings do also, require an representative scope area on ground so as to match with its dignity<o></o>
3 Just erection of one tall structure in certain congestion area cannot be considered tenable<o></o>
4 Suggested to plan buildings in many numbers in certain location for high rise, so as to socialize, utilize land use, extend its supporting services in a systematic style<o></o>
5 Since buildings being tall, can help at least in day time, provide sunlight illumination within all building premises to an extent virtually feasible<o></o>
6 Dependence on use of air conditioning should be minimized to an extent practically possible<o></o>
7 Such concept to use maximum natural energy is a follow up of green building or old ours’ concept <o></o>
8 Least use of air conditioning shall effect typical requirement on specifications of glazing on windows as well as on building external cladding & envelope<o></o>
9 Buildings should be kept provided with a distance between two buildings & two rows, which space on area can be used to facilitate location of other ancillary buildings, provision pertinent roads, services etc<o></o>
10 Gap between two such buildings helps in preventing fire from spreading to other buildings as well<o></o>
11 All such buildings remain surrounded by soft landscape all times, where on trees can be planted with complete external irrigation system<o></o>
12 Along with such buildings, group car parking lots/multi stories car ports can be added so that not to allow any car outside buildings on circulation streets/internal roads to keep township tidy & clean<o></o>
13 Reservoirs can be accommodated within such areas of landscape<o></o>
14 Fire fighting external system can also be very well accommodated<o></o>
15 Other facilities for town residents can also be easily added for its working infra structure constituents<o></o>
16 In addition to assist its residents, local markets, local schools & medical homes, police stations, substations etc can also, be provided<o></o>
17 If so required for local entertainment or recreation, swimming pools, tennis sports courts etc can also, be provided<o></o>
18 Sizes of such buildings should be designed in a way that adequate length & width should be available to encounter wind forces<o></o>
19 In case of collapse due to whatsoever cause, failed building should not adversely impact on other buildings around<o></o>
20 <v><v></v><v><v></v><v></v><v></v><v></v><v></v><v></v><v></v><v></v><v></v><v></v><v></v><v></v></v><v></v><o></o></v><v><v></v><v></v></v>Such complex delivery provision would certainly, require controls respecting rain water disposals from ground open areas, while major run off of rain water may irrigate green areas<o></o>
21 Provision of rain water preservation can be made for water discharge that is not naturally preserved in to soil strata<o></o>
22 When such type of tall buildings based complexes are planned, beautiful landscape can be included around buildings<o></o>
23 A sample indicate township sketch has been included on word format for reference information only<o></o>
24 Many such integrated complexes have been accommodated on this plan to constitute a major township <o></o>
25 Shapes of buildings in plans would contain styles so as to have varying architecture for each building<o></o>
 Download |
Filename: |
Township Key Plan.docx |
208.89 KB |
Downloaded: |
408 Time(s) |
bijay sarkar ...
Posted: Sun Nov 25, 2012 12:48 pm Post subject: |
What are the statutory clearances required for Tall Buildings?
with regards,
bijay sarkar
Posted: Sun Nov 25, 2012 4:17 pm Post subject: Statutory Clearances |
Dear Eng
Bijay Sarkar
- Tone of question tells that originator knows its answer very well, yet it has been raised for others benefit
- Planing authority/Master plan controller
- NCR- NCR Board involving all NCR chief ministers if location is NCR
- State authority involving development
- Urban development ministry
- Environment clearance/green building controls including harvesting, soft landscape, sewage treatment plant, biological waster treatment for hospitals, other uncommon waste
- Public health including sanitary/sewage/water supplies/storm water etc
- Electricity authority
- Fire authority
- Airports authority
- Standby services support controls
- Public safety controls including movements
- Possibly I could forget certain other, which shall be added later
