Econf_Moderator E-Conference Moderator
Posted: Tue Nov 20, 2012 9:12 am Post subject: Pointed discussions on tall buildings - Use of Flat Slab -co |
Dear All:
Not all of us design tall buildings. But most likely, a lot of us will be designers or project engineers for tall buildings in years to come. And needless to say, almost all of us have opinions about how things ought or ought not to be done.
We welcome comments from all engineers regarding issues they may want to comment on, on design and construction of tall buildings. If we look around us in Mumbai, NCR and most of the metros of Mumbai, majority of the new construction is tall buildings- and here I am using the IBC definition of 50 m. And almost everyone has done tall buildings, if I use the Chinese definition of 28m.
To start the ball rolling,
What is the general opinion of SEFIans to the use of flat slab with core shear wall system as a structural system for tall buildings?
- Should it be allowed in Zone V?
- Up to what max height?
- What are the conditions one may impose for use of such a system for tall buildings?
Look forward ot hearing form you all on this topic
best regards,
CVR Murty
Swaminathan Krishnan
Alpa Sheth
Econference Moderators
sarfaraj.husain ...
Posted: Tue Nov 20, 2012 10:33 am Post subject: Pointed discussions on tall buildings - Use of Flat Slab -co |
though steel buildings are not much encouraged in india........after which height it is better to go for steel building ???
sarfraj...
To: econf34289@sefindia.org,
Date: 11/20/12 03:58 PM
Subject: [E-CONF] Pointed discussions on tall buildings - Use of Flat Slab -column with shear wall core as structural system
Dear All:
best regards,
CVR Murty
Alpa Sheth
ishacon Silver Sponsor
Posted: Tue Nov 20, 2012 11:10 am Post subject: Pointed discussions on tall buildings - Use of Flat Slab -co |
Let us first be clear about using flat slab or flat plates -
the latter seems to have caught the fancy of contractors from Mumbai.
1. If it is flat plate, I would be reluctant to advocate it
for Zone V unless we do not insist on Dual system as per IS 1893,
due to the higher shear at shear wall and plate junctions.
May consider it for buildings up to 50 M height ensuring performance criteria
for human comfort in terms of the lateral drift.
In any case Flat slab with drop panel would be always more desirable
from performance basis. To what height , will still be a question I am not sure.
2. Having said as above, it becomes imperative that provisons of IS 1893 need to be
streamlined to determine appropriateTime period for shear wall buildings
VP Agarwal
ISHA CONSULTANTS (P) LTD
NEW DELHI 110074
PH : 011-2630 1158 ;
08010071749 ; 093 1345 2180
Quote: | -- Original Message --
Sent: Tuesday, November 20, 2012 4:00 PM
Dear All:
best regards,
CVR Murty
Alpa Sheth
shekhar at shekharpana... Guest
Posted: Tue Nov 20, 2012 1:01 pm Post subject: Pointed discussions on tall buildings - Use of Flat Slab -co |
Lets get going....
The three basic framing systems to resist lateral loads in high-rise buildings are: (1) Frames, (2)shear walls coupled or acting individually and (3) frames interacting with shear walls.
As an economical form of construction a shear wall structure incorporating a flat plate system is almost ideal.The flat plate system is very efficient in resisting gravity loading while the shear wall provides the resistance to lateral loads.
- Shekhar Panandiker
Please reply on our new id:
shekhar@shekharpanandiker.com (shekhar@shekharpanandiker.com) OR
info@shekharpanandiker.com (info@shekharpanandiker.com)
SHEKHAR PANANDIKER & ASSOCIATES,
Consulting Structural Engineers & Architects,
Wing A, second Floor, Hiraniketan,
Margao - Goa 403601
Tel: +91-832-2738399, 2705947
Fax: +91-832-2705947
Visit us at: www.shekharpanandiker.com
Dear All:
best regards,
CVR Murty
Alpa Sheth
Joined: 21 Feb 2008 Posts: 5436 Location: Gaithersburg, MD, U.S.A.
Posted: Tue Nov 20, 2012 1:50 pm Post subject: Re: Pointed discussions on tall buildings - Use of Flat Slab |
I totally agree with Er Agarwal, as many cases of failures have been reported in the case of flat plates/slabs located in EQ zones. Flat plates in Zone V, even in ordinary buildings, is questionable without dual lateral force resisting system. Research in the area is still continuing.
The use of Stud shear reinforcement has been advocated and found to be better in increasing the shear strength of the slab than other types of shear reinforcement.
ishacon wrote: | Dear All,
VP Agarwal
NEW DELHI 110074
Dear All:
best regards,
CVR Murty
Alpa Sheth
prasad_s General Sponsor
Posted: Tue Nov 20, 2012 1:58 pm Post subject: Pointed discussions on tall buildings - Use of Flat Slab -co |
Hello Isha mam,
Flat slab construction is not allowed in earthquake pron areas, which IS code indirectly says. Because there is no special provision for response reduction factor
which is to be applied for flat slabs. So i think may be we should opt a lesser value of response reduction factor for flat slab and study on its behaviour.
I just added to your comment. I am hoping a reply from you.
Prasad Sansare,
IIT Rookee.
Sent: Tuesday, 20 November 2012 7:00 PM
Subject: [E-CONF] Re: Pointed discussions on tall buildings - Use of Flat Slab -co
VP Agarwal
NEW DELHI 110074
: -- Original Message --
From: Econf_Moderator (forum@sefindia.org (forum@sefindia.org))
To: econf34289@sefindia.org (econf34289@sefindia.org) (econf34289@sefindia.org (econf34289@sefindia.org))
Dear All:
best regards,
CVR Murty
Alpa Sheth
kapildingare ...
Posted: Wed Nov 21, 2012 5:46 am Post subject: |
Resp. Sefians,
As Er. Shekhar has pointed ,
1) Flat plate with shear walls is most economical form of construction.
2) Along with that there are two other form of structural combinations that can be used to resist gravity and lateral loads as he has noted.
But Resp Dr Subramanian and Resp. Agrawal has noted there are many cases of failures when in severe earthquake zone flat plates with shear walls as lateral load resisting system are used.
What I feel is Er Shekhar has given vital information but what Dr Subramanian is advising is more interesting .
BECAUSE we can design and construct a building which can resist DESIGNED earthquake induced forces with all three structural combinations Er Shekhar has mentioned but in case of earthquake of more intensities than designed one(as it is expected ) mode of failure or type and extent of damage /failure will be different for all the three structural combinations. My opinion it will be worst in case of flat plate with shear walls.
I would like to get expert opinion on relative extent of damage with respect to these three forms when such structure is exposed to severe earthquake than designed earthquake.
Kapil Dingare
SANGEETA WIJ ...
Posted: Wed Nov 21, 2012 6:03 am Post subject: Pointed discussions on tall buildings - Use of Flat Slab -co |
Dear Alpa
I had raised a query a few weeks ago to ask the following:
<![if !supportLists]>· <![endif]>whether there is a rule as to what % of tower columns must go to the basement raft level(hypothetically, the architect wants all tower columns to be supported only on transfer girders, let’s take a typical tower of G+20 and three basements which are full plot size). How does the overall tower stability get affected in such a case, especially in zone-IV EQ?
<![if !supportLists]>· <![endif]>What are the guidelines for Seismic separation/Expansion joints in such large basements(say it’s a 100 acre plot with 20 scattered towers).Do we or do we not give joints in the non-tower basement structure? If yes, then at what spacing? (chances are, that each part of basement may carry more than one tower, making it a very complex modelling challenge)
<![if !supportLists]>· <![endif]>When does the wind tunnel test become mandatory, between two adjacent high rise blocks?
Sangeeta Wij
From: shekhar at shekharpana... [mailto:forum@sefindia.org]
Sent: 21 November 2012 10:36
Lets get going....
shekhar@shekharpanandiker.com (shekhar@shekharpanandiker.com) (shekhar@shekharpanandiker.com (shekhar@shekharpanandiker.com)) OR
info@shekharpanandiker.com (info@shekharpanandiker.com) (info@shekharpanandiker.com (info@shekharpanandiker.com))
Margao - Goa 403601
823 Bytes |
Viewed: |
922 Time(s) |
anandkamath SEFI Member
Posted: Wed Nov 21, 2012 7:06 am Post subject: Pointed discussions on tall buildings - Use of Flat Slab -co |
Dear AllWhy are not using steel structures with precast wall for tall buildings.RegardsAnandSent from BlackBerry® on Airtel
Date: Wed, 21 Nov 2012 11:16:46 +0530
To: <econf34289@sefindia.org>
Resp. Sefians, As Er. Shekhar has pointed , 1) Flat plate with shear walls is most economical form of construction. 2) Along with that there are two other form of structural combinations that can be used to resist gravity and lateral loads as he has noted. But Resp Dr Subramanian and Resp. Agrawal has noted there are many cases of failures when in severe earthquake zone flat plates with shear walls as lateral load resisting system are used. What I feel is Er Shekhar has given vital information but what Dr Subramanian is advising is more interesting . BECAUSE we can design and construct a building which can resist DESIGNED earthquake induced forces with all three structural combinations Er Shekhar has mentioned but in case of earthquake of more intensities than designed one(as it is expected ) mode of failure or type and extent of damage /failure will be different for all the three structural combinations. My opinion it will be worst in case of flat plate with shear walls. I would like to get expert opinion on relative extent of damage with respect to these three forms when such structure is exposed to severe earthquake than designed earthquake. Kapil Dingare
mjnasar ...
Posted: Wed Nov 21, 2012 12:59 pm Post subject: Fire Safety In Tall Buildings & Role of Structural Engin |
Please tell us more about Fire safety & evacuations issue and structural engineers role in it
Following are the some points:
<![if !supportLists]>1- <![endif]>Standards of Fire rating in Hrs for Various structural elements
<![if !supportLists]>2- <![endif]>Role of Concrete covers / concrete encasement in Fire safety
<![if !supportLists]>3- <![endif]>Chemicals to improve fire ratings
<![if !supportLists]>4- <![endif]>Evacuation issues
<![if !supportLists]>5- <![endif]>Progressive collapse issues
<![if !supportLists]>6- <![endif]>Blast Resistant construction for certain elements
mjnasar
Sent: Tuesday, November 20, 2012 4:30 PM
VP Agarwal
NEW DELHI 110074
Dear All:
best regards,
CVR Murty
Alpa Sheth
823 Bytes |
Viewed: |
867 Time(s) |
