raqueeb_ali SEFI Member
Posted: Wed Nov 28, 2012 4:39 am Post subject: Role of Cladding system in Tall buildings |
Dear Experts,
I want to know the roll of Cladding System in tall buildings. How do cladding system interact frame elements. If u have any papers in reference to role of cladding in tall buildings please enlighten us with it.
Raqueeb. |
B.V.Harsoda General Sponsor
Posted: Wed Nov 28, 2012 12:01 pm Post subject: |
Paper:-
DUCTILE CLADDING SYSTEMS FOR SEISMIC DESIGN (Tall Building)
James I CRAIG
1
, Barry J GOODNO
2
, Peeranan TOWASHIRAPORN
3
And Tumay DOGAN
4
SUMMARY
Architectural cladding offers the potential for passive response modification in building structures designed to resist seismic loadings. The cladding connections can be designed to dissipate energy through inelastic material hysteresis driven by seismically induced interstory drift. When properly designed, precast cladding panels can easily support the added interstory forces and the ductile connectors can stably dissipate energy without compromising connection integrity. From a design point of view, this passive response modification can be used to (a) improve serviceability or (b) reduce cost. Improved serviceability is achieved by optimizing the
connectors to maximize energy dissipation and consequently to reduce the peak drift. Reduced cost, as measured by reduced structural weight, is achieved by starting with a baseline structural
design and systematically reducing member sizes while adding passive damping in the connectors while maintaining the same baseline performance (as measured by peak drift). Approach (a) is shown to reduce peak displacements by more than 40% from baseline values and has potential for both new and retrofit/rehabilitation applications. Approach (b) is shown to
reduce structural weights in new designs by at least 14% for the most conservative design assumptions.
Source Link:-
http://www.iitk.ac.in/nicee/wcee/article/1604.pdf
Er. B. V. Harsoda |
Posted: Wed Nov 28, 2012 12:05 pm Post subject: |
Papers Links:-
Dynamic behavior of tall building with cladding
http://www.iitk.ac.in/nicee/wcee/article/5_vol2_2769.pdf
Earthquake resistance and behavior of heavy facades/cladding & connections in medium-rise steel-framed buildings
http://www.iitk.ac.in/nicee/wcee/article/9_vol6_207.pdf
Use of advance cladding system for passive control of building responce in earthquakes.
http://www.iitk.ac.in/nicee/wcee/article/10_vol7_4195.pdf
Influence of interstory drif on cladding panels and connection
http://www.iitk.ac.in/nicee/wcee/article/9_vol6_213.pdf
Er. B. V. Harsoda |
Posted: Thu Nov 29, 2012 5:08 pm Post subject: |
Thanks for your valuable suggestions. Those are really helpful.
Regard,
Raqueeb Ali |
