AAC block
dldesai
PostPosted: Sat Feb 02, 2013 5:23 am    Post subject: AAC block Reply with quote
At present scenarion AAC Block used for the Massonary work inspite of using Brick.
I Want to know that AAC Block canbe used for UG TANK massonary ?
Request to all collageous and seniors to give their feedback.
Thanks,
D.DEsai
Manoharbs_eq
PostPosted: Fri Feb 08, 2013 9:48 am    Post subject: Reply with quote
NO, If we refer to the properties of AAC, we can clearly see that IT is porous and light weight.
any material to be proven for UGtank is
1) It must be less porous
2) The element undergoes lateral load when full and no soil fill and soil pressure in empty case. hence resistance to these load is essential.
Rgds
Manohar
abhio
PostPosted: Fri Feb 08, 2013 11:51 am    Post subject: Reply with quote
Would you build a tank in masonry at all?
Manoharbs_eq
PostPosted: Fri Feb 08, 2013 11:59 am    Post subject: Reply with quote
Small UG sumps upto 1.5 to 2m are constructed in brick or solid block masonry.
Rgds
Manohar
dldesai
PostPosted: Tue Feb 19, 2013 12:20 pm    Post subject: Reply with quote
If we can use the same size as used as Brick , and density of the same is matching..
Awaiting your valuable feedback.
D.DEsai
Rgds
Manohar
PostPosted: Tue Feb 19, 2013 1:40 pm    Post subject: Reply with quote
Dear Er Desai,
It is not the size. It is the property of the material that counts. As rightly pointed out by Er Manohar, the aerated concrete block, as the name itself implies, will have lot of pores, which are purposely introduced to make it lightweight. They can be used for partition walls to reduce the weight. They should not be used for retaining water. In fact even brick walls are not good, even though they are used in small overhead tanks. It is preferable to keep the height of such brick walled tanks to about 2.5 feet. I have seen many tanks malfunctioning. Even in my office it started leaking and we totally abandoned it and using a plastic tank instead.
D.DEsai
Rgds
Manohar
dldesai
PostPosted: Thu Feb 21, 2013 12:30 pm    Post subject: Reply with quote
Thanks, for your valuable feedback, i appologize myself for late replying you.
REgards,
D.DEsai
Dr. N. Subramanian wrote:
Dear Er Desai,
D.DEsai
Rgds
Manohar
thirumalaichettiar
PostPosted: Mon Feb 25, 2013 4:27 pm    Post subject: Reply with quote
Dear Dr.N.S.,
If we use composite construction that is, if we pour concrete with nominal reinforcement sanwitched between the Areated concrete block and if we add chicken mesh and plaster inside the tank will it not be solution to U.G tanks?
I recommend and use this type of composite U.G tank for apartments with 4.5" brick on either side of concrete wall of 3 to 4.5" thick poured after building in stage of 3' height. Even I used it for basement wall instead of concrete retaining wll which saved a lot money and more stronger one.
T.RangaRajan.
PostPosted: Mon Feb 25, 2013 4:34 pm    Post subject: Reply with quote
Dear Er Rangarajan,
Ferrocement water tanks have be used- SERC has also published a small booklet for the design as well as giving ready made charts for various capacities, but the cement slurry should be applied with pressure so that we get a dense matrix. Important thing is that the material we use is impervious and able to take the tensile forces generated without much appreciable cracking.
Warm regards,
thirumalaichettiar wrote:
Dear Dr.N.S.,
T.RangaRajan.
dldesai
PostPosted: Tue Feb 26, 2013 9:24 am    Post subject: Reply with quote
Dear Sirs,
Kndly refer the attached file for the U.G.Tank design like,
Give your valauble feedback for improvement..
D.L.desai
WATER TANK 260213-Model.pdf
 Filename:  WATER TANK 260213-Model.pdf
 Filesize:  91.52 KB
 Downloaded:  298 Time(s)
