staad pro
harishdutt99
PostPosted: Wed Feb 13, 2013 1:55 pm    Post subject: staad pro Reply with quote
HELLO EVERY ONE
I wanted to analyse a multistory building for both the static and dynamic cases i have done some of the calculations and i further need to calculate the wind loads and need to do the time history analysis can any one help me
I am attaching the sttad model
thanks in advance
Structure1.rar
 Filename:  Structure1.rar
 Filesize:  6.61 KB
 Downloaded:  617 Time(s)
md zeeshan ali
PostPosted: Thu Nov 14, 2013 2:53 pm    Post subject: Reply with quote
pls specify the location of the building so that  i can collect some data like basic wind speed,  earthquake zone and past earthquake time history data.
best regard
md zeeshan ali
md zeeshan ali
PostPosted: Mon Nov 18, 2013 5:24 pm    Post subject: Reply with quote
DEAR SIR
SOON I WILL UPLOAD DYNAMIC AND WIND LOAD ANALYSIS ALSO
STATIC EARTHQUAKE LOADING.txt
 Filename:  STATIC EARTHQUAKE LOADING.txt
 Filesize:  26.03 KB
 Downloaded:  789 Time(s)
md zeeshan ali
PostPosted: Tue Jan 28, 2014 5:55 pm    Post subject: earthquake analysis through response spectrum method Reply with quote
the below attache file will run in ss3 and above..... because single mass model is being used.
EQ LOADING BY RESPONSE SPECTRUM.txt
 Filename:  EQ LOADING BY RESPONSE SPECTRUM.txt
 Filesize:  40.83 KB
 Downloaded:  724 Time(s)
rkyadav
PostPosted: Wed Jan 29, 2014 12:46 am    Post subject: Reply with quote
Could you please check it again, there are many errors.
R K Yadav
md zeeshan ali
PostPosted: Thu Jan 30, 2014 1:32 pm    Post subject: Reply with quote
dear
I have checked the file, it is in the healthy condition with zero error and 11 warnings ( for the over-reinforced section).
I strictly advice you to run the file on the STAAD Pro (SELECTseries3) and above. if you haven't the latest version. i will upload staad code for that , if you will need it.
