Help
Afia.S.Hameed
PostPosted: Tue Mar 26, 2013 9:17 am    Post subject: Help Reply with quote
i need to do my project for the completion of my Post Graduation.. please help me to find a topic and i am confused whether to do experimental or theorectical. Also i would lik to do in Concrete
syed_A
PostPosted: Tue Mar 26, 2013 10:56 am    Post subject: Reply with quote
Hello
As far concrete topic is concerned, I feel you should try or dig more for the following topic are as follows
1> strengthening old and deteriorated elements in a RCC structures
2> alteration and modifications such as removing/adding   columns etc etc
     beams, slabs or footing capacity
Best regards
Afia.S.Hameed
PostPosted: Tue Mar 26, 2013 2:34 pm    Post subject: Reply with quote
syd_hyd wrote:
Hello
Best regards
Thank you so much sir for ur kind reply. may I ask you one more thing It wil be good doing experimental Project on the first topic you suggested but do u have any ideas in which way i have to move.....
shariffmn
PostPosted: Wed Mar 27, 2013 7:51 am    Post subject: Reply with quote
For doing a good project, you need facilities and a person to guide you.
You can either do experimental or analytical project, it all depends on the facilities you have at your college. Experimental is usually more valued because it creates a set of database, which can be useful to many others. Analytical work gives you the scope to solve difficult problems or iterative problems, where experiments prove to be too costly. Both modes have their pros and cons. What you need it a strong understanding of the project work. If you know your project inside out, you have learnt a lot!
This is what you are supposed to do:
1. Identify your thrust area.
2. Identify a good advisor whose thrust area matches with that of yours.
3. Decide on a topic after discussing with him. Of course, you can do some literature review and see what are the on-going projects in your field of interest, to get a lead.
4. Whenever you have a question, ask on this forum. The excellent pool of structural engineers can give you expert advise.
All the best!
Shariff M N
Afia.S.Hameed
PostPosted: Tue Apr 02, 2013 10:16 am    Post subject: my PG Project Reply with quote
RESPECTED FORUM
i at last thought of doing a project based on retrofitting of deteriorated structures...... many researchs had undergone using FRP,GFRP. CFRp etc.........so i would like to use some other material. can you plsease suggest some material for the experimental project.
thanking you so much
syed_A
PostPosted: Tue Apr 02, 2013 4:11 pm    Post subject: Reply with quote
Hello
Kindly share your project after finishing, by the way I shall try to find any material/books related to this topic (retrofitting)You may check this links, might be helpful
my email ID smah2008@gmail.com
http://www.sefindia.org/forum/viewtopic.php?t=13424&highlight=adding
http://www.sefindia.org/forum/viewtopic.php?t=12401&highlight=adding
http://www.sefindia.org/forum/viewtopic.php?t=12302&highlight=adding
http://www.sefindia.org/forum/viewtopic.php?t=10803&highlight=adding
http://www.sefindia.org/forum/viewtopic.php?t=10085&highlight=adding
http://www.sefindia.org/forum/viewtopic.php?t=9951&highlight=adding
http://www.sefindia.org/forum/viewtopic.php?t=9323&highlight=adding
http://www.sefindia.org/forum/viewtopic.php?p=32793&highlight=#32793
http://www.sefindia.org/forum/viewtopic.php?t=8307&highlight=adding
http://www.sefindia.org/forum/viewtopic.php?t=7696&highlight=adding
http://www.sefindia.org/forum/viewtopic.php?t=4326&highlight=adding
good luck
