Fireproofing weight -STAAD.Pro help
chanducivil
PostPosted: Mon Jun 03, 2013 12:52 am    Post subject: Fireproofing weight -STAAD.Pro help Reply with quote
Dear all,
As I know, STEEL TAKEOFF gives the total weight of steel members that are used in a model in STAAD.Pro...similarly is there any command for getting FIREPROOFING WEIGHT directly in output file...?
Please let me know if someone know this...
Thanks and Regards,
Chandu
md zeeshan ali
PostPosted: Thu Nov 14, 2013 2:55 pm    Post subject: Reply with quote
dear sir
as per my knowledge there is nothing like that.
but if, i would also like to know..
md zeeshan ali
umeshrao
PostPosted: Wed Feb 12, 2014 11:30 am    Post subject: Re: Fireproofing weight -STAAD.Pro help Reply with quote
chanducivil wrote:
Dear all,
Please let me know if someone know this...Thanks and Regards,
Chandu
Dear Mr. Chandu,
This load is not to be mistaken for load [ as force] since it is not because of gravitational acceleration.
This is a terminology used identify the fire resistance that needs to be considered. Concrete element dimensions and cover to reinforcement is a function of fire resistance defined in hours[ as in IS 456]. To give escape materials used  in the construction. In RCC cover to reinforcement  is provided so that temperature of steel in case of fire should not reach high so that modulus of elasticity is not dropped down suddenly endangering structure.
This fire load to be resisted is defined in lbs/sft or kg/sqm. For example, residential buildings are designed for fire load of 8.5 lbs/sft. or 42 kg/sqm. while office building may be designed for fire load about 2 to 3 times higher.
Umesh Rao
