response No 20 red oxide prevents the corrosion of steel ba
inchak at tatasteel.com
Guest
PostPosted: Mon Jul 04, 2005 7:19 am    Post subject: response No 20 red oxide prevents the corrosion of steel ba Reply with quote
Dear Mr. Mukesh Upadhyay
This is a very valid doubt.
Whatever be the means to achieve improved corrosion resistance to rebars
embedded in concrete it boils down to formation of an adherent continuous
protective flim on the surface of the rebar. This is the underlying
principle of CRS rebars, galvanized rebars, epoxy coated rebars, stainless
steel rebars etc.
Presence of red oxide in cement does not lead to formation of any such
coating on the surface of rebar. Therefore, there should be no significant
difference in corrosion rate of  any particular type of rebar it it is
embedded in ordinary cement or in a cement which contents some amount of
red oxide.
This can be easily tested in any laboratory and a conclusive evidence can
be arrived at. A competent member of this forum may like to take this up.
********************************DISCLAIMER***********************************
Information contained and transmitted by this e-mail is confidential and
proprietary to Tata Steel Ltd. and is intended for use only by the
addressee. If you are not the intended recipient , you are notified that
any dissemination or copying of this e-mail is strictly prohibited and you
are requested to delete this e-mail immediately and notify the originator.
Tata Steel does not enter into any binding agreement with any party by
e-mail. Any views expressed by an individual do not necessarily reflect the
view of Tata Steel. Tata Steel is not responsible for the consequences of
any actions taken on the basis of information provided. While this e-mail
has been checked for all known viruses the addressee should also scan for
viruses. To know more about Tata Steel please visit www.tatasteel.com
