IS800:2007 Query - Earth quake resistant design
mtamil
PostPosted: Wed Sep 24, 2014 6:26 pm    Post subject: IS800:2007 Query - Earth quake resistant design Reply with quote
"12.4.2 All welds used in frames designed to resist earthquake loads shall be complete penetration butt welds, except in column splices, which shall conformto12.5.2."
The above clause of IS800-2007 is bit of a surprise for me. I do understand that Beam-Column connections can meet this provision; as well the gussets welded to Beams/Columns.
But, I fail to understand how this provision can be met with, where an Angle bracing is welded with a gusset.
Are butt welds feasible between the gusset and bracing?
How  butt welds improve ductility/siesmic performance, especially when the action is  in the line of the weld (unlike a moment plate welded to the column)?
Learned sefians may please throw some light on the subject.
Tamilarasan.
vegad
PostPosted: Fri Oct 03, 2014 2:02 am    Post subject: Reply with quote
Dear Member,
The code simply calls for less risk may be to cover up the kind of quality protocols generally afforded by our practices in welding. Even partial penetration welds considered stronger than fillet are not allowed, except in column splices for enhanced strength.
And worst, it applies to frames in all seismic zones; that indicates the level of confidence while defining seismic zones.
The clause in question calls for mechanism overhaul.
Only option left while complying to IS 800 is to keep least number of seismic paths sharing least gravity loads and providing "only bolt connections" where required in those paths.
Rest all can be designed for deformation compatibility and as usual connections.
So it simply means the connections types mentioned by you can only be done in bolts, if they lie in seismic load path.
Other option is to follow non-Indian code, if it suits the requirement.
Thank you.
(not so learned person)
mtamil
PostPosted: Sat Oct 04, 2014 4:45 am    Post subject: Reply with quote
vegad wrote:
Dear Member,
Thank you.
Hi vegad,
Thanks for sharing your thoughts. I felt this part the code did fail to consider the practicalities of implementation.
Provisions under section 12 have put practicing engineers in the crossroads.
Tamilarasan
