Fe 550
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 20th June 2005
p_kadam at vsnl.com
PostPosted: Thu Jul 21, 2005 11:39 am    Post subject: Fe 550 Reply with quote
Dear all,
Refer Article Steel-Reinforcement by Dr P C Basu.
"Cautious approach" is advised while using Fe 550. It has not been ruled out.
regards,
P Kadam
 Dear Mr. Kadam,
> The high yield strength steel produces higher factored shears and they
> have to be carried by the beam without exceeding the maximum shear
> stress Tcmax given in Table 20 of I.S. 456 : 2000 even though shear
> reinforcement is provided. Therefore, higher concrete sections
> will be
> required for beams to resist shears produced during earthquake episode
> and it has futhther implications on the stiffness of the frame that
> has additional adverse effect on the force distribution and will
> attrect higher earthquake forces
> This means the proposed steel having high yield strength such as Fe
> 600 is not welcome and if you look at New Zealand code AS/NZS
> 4671-2001, they have only Fe 300E and Fe500E category steel.
> Neelkanth D Joshi
> Joshi Consultants
> joshiconsultants9@gmail.com
> The views, opinions, analyses and assessments contained herein do
> not necessarily reflect the views of SEFI or TATA Steel. Also SEFI
> and TATA Steel does not guarantee the accuracy of the data
> included in the proceedings of this e-conference and accepts no
> responsibility for any consequences of their use.
> ========powered by Reach1to1 Office Everywhere
This forum is locked: you cannot post, reply to, or edit topics.This topic is locked: you cannot edit posts or make replies.    www.sefindia.org Forum Index -> E-Conference 20th June 2005 All times are GMT
