jigar_mehta SEFI Member
Posted: Sat Nov 21, 2015 5:31 am Post subject: Modelling of Active damper in SAP Etabs or Stadd pro |
Respected Sir,
My topic for ME dissertation is comparision of siesmic analysis between actvie and passive damping system. In this project i will show time history analysis between active n passive dampers installed in a building of various heights. now the problem is how will i model active damper in softwares like sap, etabs or stadd pro.?? |
rahul.leslie General Sponsor
Posted: Tue Nov 24, 2015 10:15 am Post subject: |
Active and passive damping system? It's easy to do passive in SAP. But how active? In real buildings, you need a real time microprocessor (or computer) processing real time readings from accelerometers, and sending contolls to the active dampers - whether the damper is moving a TMD, or placed as diagonals in bays. You may use something like VHDL (or C) to program these microprocessors ( I don't know what they actually use).
In FE packages, you'll have to write a program taking in one data (accelerations), processing, and turning out the other (strain in damper). ANSYS has APDL, i believe it should do the trick. SAP also has a programming link (an API), which... i don't know much about. It might be able to be used for this.
Rahul Leslie
Posted: Tue Nov 24, 2015 10:25 am Post subject: |
Thank u so much for your guidance sir.. |
