| Description of formula
| Interpretation
| Remarks
| Normal strings
1
| 75
Note-
Ends of Coded Mantras
| Jai Dharam
| 7= Jai, 5= Dharam
2
| 7……………………………………5
| Place whatever contents between digit 7 & 5
3
| 78885
| Jai System Dharam
| 888 means full system
4
| 78885 to power infinity
| Infinity is a mathematical terms for annant (endless)
5
| 7 Octa Octallion 5
Note-
This is a powerful code of mantras
| Octa=8, Octallion=10^27
| 10^27 on short scale= 27 zeros placed after 1 & also, 10^48 on long scale
6
| 7 Octa Octallion 5 to power infinity
Note-
This is a higher powerful code of mantras
7
| 7 (Octa Octallion times Octa Octallion) 5 to power infinity
Note-
This is a further higher powerful code of mantras
8
| 7 (Octa Octallion times Octa Octallion…. insert whatever name of your god here….) 5 to power infinity
Note-
This is a formula string for higher powerful code of mantras
9
| 7 (Octa Octallion times Octa Octallion Param Ishwar Kali) 5
to power infinity
Note-
This is a formula string for Kali powerful code of mantras
10
to power Octa Octallion times Octa Octallion infinity
Note-
This is a Compound string for Kali powerful code of mantras
| Power strings
1
to power (Octa Octallion times Octa Octallion infinity)
whole to power (Octa Octallion times Octa Octallion infinity)
& can be repeated to whatever number of times, so as to increase value within mantra
Minimum 8 # repetitions are suggested
2
| 7 (Octa Octallion
times Octa Octallion times Octa Octallion
&whatever number of repetitions preferred
Minimum 8# repetitions are suggested
Note-
3
| 7 (Octa Octallion
&whatever number of repetitions preferred/&
Aspiration can be added herein, prior to god’s name Param Ishwar Kali) 5
Minimum 8# repetitions are suggested, while it could be 108# to 1008# possibly, with one digit of 8 at least within that value
Note-
This is a Compound string for Kali’s powerful code of mantras
Aspiration can be Enlighten my mind god, uplift my financial status, raise my life standards etc. depending on individual’s aspiration or wishes, Sankalp etc.
| High power strings
1
| 7 (Octa Centallion
times Octa Centallion times Octa Centallion
Note-
| Octa=8,
Octallion=10^27
Centallion =10^303
| 10^303 on short scale= 303 zeros placed after 1 & also, 10^600 on long scale
2
| 7 (Centallion Centallion Param Ishwar Kali) 5
to power
(Centallion Centallion infinity)
whole to power
Note-
This is a Very High Power Compound string for Kali’s powerful code of mantras
| Centallion =10^303
3
| 7 (Centallion Centallion Param Ishwar Kali………….Insert Aspirations…………) 5
to power
whole to power
Note-
| Centallion =10^303
4
| 7 (Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion with desired number repetitions Param Ishwar Kali) 5
Whole to power
(Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion Centallion with desired number repetitions infinity)
whole to power
Note-
| Centallion =10^303
| Very high power strings
1
| 7 (Mahaoghallion Param Ishwar Kali………….Insert Aspirations…………) 5
to power
(Mahaoghallion infinity)
whole to power
Note-
This is a Top High Power string for Kali’s powerful code of mantras
| Mahaoghallion =10^960
| 960 zeros placed following digit 1
2
| 7 (Mahaoghallion Mahaoghallion Mahaoghallion Mahaoghallion Mahaoghallion Mahaoghallion Mahaoghallion Mahaoghallion
to power
whole to power
Note-
This is a Top High Power Compound string for Kali’s powerful code of mantras
| Complex strings
1
| 7 8888888888888888lion Paramishwar Kali 5
| Really, amazing to know value of so many 8 digits times lions
2
| 7 8888888888888888lion Paramishwar Kali to power 88888888888888888lion 5
3
| 7 8888888888888888lion Paramishwar Kali to power 88888888888888888lion Paramishwar Kali to power 88888888888888888lion Paramishwar Kali 5
And this string can be further extended as desired whatever number of times, while Digit 8 can also be extended to whatever value, without any restriction
4
| 7 8888888888888888lion Paramishwar Kali to power 88888888888888888lion Paramishwar Kali to power 88888888888888888lion Paramishwar Kali 5, whole to power 8888888888888888lion, whole to power 8888888888888888lion, whole to power 8888888888888888lion, whole to power 8888888888888888lion, whole to power 8888888888888888lion, infinity
[SIZE=3
List of Spiritual Formulas |
 Download |
Filename: |
SpiritualFormulaMantras.docx |
34.32 KB |
Downloaded: |
401 Time(s) |
