How to calculate External pressure coefficients for Wind loads as per IS 875 for irregular shaped high rise buildings?
Sayyad_Wajed
PostPosted: Tue Jun 14, 2016 6:27 am    Post subject: How to calculate External pressure coefficients for Wind loads as per IS 875 for irregular shaped high rise buildings? Reply with quote
General Data of the Building:
·    Height: 106.4m from ground level (B+G+32), 5.1 meter below GL
·    Plan: As shown
·    Location: Mumbai
·    Terrain category: 3
·    Class of structure: B
·    Topography factor: 1
Senior Practicing Engineers/Professors please help???
https://www.linkedin.com/pulse/how-calculate-external-pressure-coefficients-wind-loads-ali
 Filesize:  762.93 KB
 Viewed:  508 Time(s)
rajancivildesign@gmail.co
PostPosted: Wed Jun 15, 2016 6:47 am    Post subject: Procedure for calculation of wind load on building Reply with quote
Dear SAFIAN,
For calculating wind load and external pressure coefficient you can refer Chapter 11 on reinforced concrete Vol II by H.J.SHAH. As your a new to STAAD pro, i herewith attached Wind load design procedure and application of wind load in STAAD Pro with example  for your guidance. the examples  are prepared by me only.
V.M.RAJAN.
day 11Wind load analysis.pdf
 Filename:  day 11Wind load analysis.pdf
 Filesize:  717.62 KB
 Downloaded:  3177 Time(s)
Day 10- wind analysis.pdf
 Filename:  Day 10- wind analysis.pdf
 Filesize:  472.79 KB
 Downloaded:  38193 Time(s)
PostPosted: Wed Jun 15, 2016 2:41 pm    Post subject: Reply with quote
Dear Rajan Sir,
Similar to the wind load analysis, do you have latest notes on EQ analysis of RCC buildings using STAAD ?
syed_A
PostPosted: Wed Jun 15, 2016 3:39 pm    Post subject: Reply with quote
Er V.M.Rajan sir
Thanks for the excellent pdf file to calculate the wind load both manual and using staadpro
best regards
