Earthquake analysis as per IS1893 using staad pro
Goto page 1, 2, 3  Next
rajancivildesign@gmail.co
PostPosted: Thu Jun 16, 2016 3:31 pm    Post subject: Earthquake analysis as per IS1893 using staad pro Reply with quote
Dear E.S.Jayakumar Sir,
As requested the Earthquake Analysis Procedure for static method with reference to IS 1893 along with Staad pro example is attached for reference and benefit of fresh Engineers.
V.M.RAJAN.
Member weight method .pdf
 Filename:  Member weight method .pdf
 Filesize:  218.05 KB
 Downloaded:  1559 Time(s)
lumped mass method example .pdf
 Filename:  lumped mass method example .pdf
 Filesize:  67.15 KB
 Downloaded:  2926 Time(s)
seismic analysis Lumped Mass procedure.pdf
 Filename:  seismic analysis Lumped Mass procedure.pdf
 Filesize:  2.11 MB
 Downloaded:  3653 Time(s)
Earthquake Analysis procedure .pdf
 Filename:  Earthquake Analysis procedure .pdf
 Filesize:  39.37 KB
 Downloaded:  9949 Time(s)
Thankful People
PostPosted: Fri Jun 17, 2016 2:51 pm    Post subject: Dynamic Analysis-Response Spectrum Method Reply with quote
Dear SAFIAN,
In continuation to Static method, I herewith attached the Dynamic Analysis-Response Spectrum Method for reference to fresh engineers. If any comments on method on earth quake analysis, expert opinion  is invited.
V.M.RAJAN.
Dynamic-Response.pdf
 Filename:  Dynamic-Response.pdf
 Filesize:  266.54 KB
 Downloaded:  3638 Time(s)
PostPosted: Sat Jun 18, 2016 5:44 am    Post subject: Reply with quote
Thank you, Rajan Sir. Your contributions to this forum are really commendable.......
PostPosted: Sun Jun 19, 2016 7:50 am    Post subject: Earthquake analysis as per IS1893 using staad pro Reply with quote
Dear Jayakumar sir,
Thank you for your reply. Here I want to mention one errata in my posting. The size of building for lumped mass and member weight method as per sketch is 15m x 15m. But in my text it is mentioned as 12mx12m. Kindly corect the size and and read it. In geometry step also length along X and Z is 15m with 5 bays with each bay 3m. If somebody master in Staad pro use different method, kindly indicate the procedure if they want to mention. If anybody wants other procedure on time history, mode shape, natural frequency on rayleigh and eighen value extraction method, I shall post it in this forum for reference. Thank you for the interest shown by members.
V.M.RAJAN.
PostPosted: Sun Jun 19, 2016 3:32 pm    Post subject: Time History Method Reply with quote
Dear SAFIAN,
In continuation to dynamic earthquake analysis, Time History method is attached for reference to our members.
V.M.RAJAN
EQ DATA.rar
 Filename:  EQ DATA.rar
 Filesize:  189 Bytes
 Downloaded:  956 Time(s)
Time History method.pdf
 Filename:  Time History method.pdf
 Filesize:  201.23 KB
 Downloaded:  3210 Time(s)
aditya
PostPosted: Mon Jun 20, 2016 5:07 pm    Post subject: Reply with quote
Dear Rajan Sir,
Thanks a lot for uploading the examples which are really very usefull to all of us.
Can you explain the use of IMB, IPLM and PLASTIC commands to be used while using IS 13920 design in Staad.Pro? Can you give specific example citing when to use or not to use these commands?
with best regards,
Aditya
PostPosted: Tue Jun 21, 2016 4:58 am    Post subject: Earthquake analysis as per IS1893 using staad pro Reply with quote
Dear Aditya,
I am  not expert in staad pro. I request our  senior engineers like Pandiya sir or others who are well experienced in staad pro can reply for this. still I am in learning stage only. Thank you,
V.M.RAJAN.
aditya
PostPosted: Wed Jun 22, 2016 1:16 am    Post subject: Reply with quote
Dear Sukant Adhikari Sir, Arun Kumar Sir and other fellow Sefians,
May I request for your help in this regard?
with best regards to all,
Aditya
PostPosted: Wed Jun 22, 2016 1:40 pm    Post subject: Earthquake analysis as per IS1893 using staad pro Reply with quote
Dear SAFIAN,
To conclude this topic on earthquake analysis,
I herewith attached the method for calculating frequency on  RCC Building
for the use of fresh engineers.
V.M.RAJAN.
Eigen value Extraction method-.pdf
 Filename:  Eigen value Extraction method-.pdf
 Filesize:  89.6 KB
 Downloaded:  1727 Time(s)
Rayleigh Freqency method.pdf
 Filename:  Rayleigh Freqency method.pdf
 Filesize:  55.44 KB
 Downloaded:  1736 Time(s)
ganesh_gaud
PostPosted: Thu Jun 23, 2016 10:14 am    Post subject: Reply with quote
very useful work by rajan sir, thanks for posting.
Ganesh
Page 1 of 3
