pradeep k pawar SEFI Member
Posted: Sun Jun 12, 2016 3:48 pm Post subject: Help needed |
Respected SEFIAN'S
I am analyzing an Irregular 20 storied building through staad using response spectrum analysis method for my thesis work. There are 3 different cases
1. Without shear wall building
2. Shear wall upto full height of the building.
3. Shear wall upto 50% height of building
After doing analysis it is observed that
1. The story drift in without shear wall building increases upto middle story and than it starts decreasing but in building having shear wall upto full height story drift keeps on increasing upto full height of the building.
2. The story drift in full shear wall building is lower than without shear wall building upto middle stories but surpasses after the middle stories.
3. In the case of curtailed shear wall story drift first increases upto the height of curtailment and then starts decreases.
Can anyone please throw some light why this is happening as i think shear wall increases the stiffness so it should help in reducing the story drift and how can the story drift in a building with shear wall surpasses the story drift in building without shear wall. |
meerameen SEFI Member
Posted: Thu Aug 11, 2016 1:56 pm Post subject: |
Dear sir,
Send me your model . I shall check and revert back. |
VPandya General Sponsor
Posted: Fri Aug 12, 2016 4:07 am Post subject: STAAD SHEAR WALL FRAME FILE ATTACHED. |
Dear Sefi Engrs Pradeep Pawar and Meerameen,
I do not know if this will help but I have an example problem in STAAD with Shear Wall and Frame of a 4 story Building.
Shear Wall Frame STAAD File attached :
Vasudeo Pandya P.E.
Strucural Engineer
