Long Span Flat slab Design Help
chandra_s_eng
PostPosted: Tue Nov 08, 2016 7:20 am    Post subject: Long Span Flat slab Design Help Reply with quote
Hello Everyone
I need expert suggestions regarding single long span Flat Slab design with perimeter beams.
I have designed a flat slab using a software Safe. Here the condition is it has continuous   spans in one direction and single span in other direction and the span is around 31 foot.
Geometry:
Slab thickness = 300mm
Drop thickness = 400 mm
Loading:
Floor Finish = 1.5 kn/sqm
Partition     =  1.5 kn/sqm
Live Load   =   3.0 kn/sqm
I need an expert suggestion whether my design is safe and valid or not. If the design is not safe, please suggest correct method and procedure. This is challenging task for me, i need to submit this design to my college.
I am attaching the safe file and detailed drawing for your review.
Chandra.
Flat Slab Reinforcement-2.pdf
Top Reinforcement
 Filename:  Flat Slab Reinforcement-2.pdf
 Filesize:  207.44 KB
 Downloaded:  469 Time(s)
Flat Slab Reinforcement-1.pdf
Bottom Reinforcement
 Filename:  Flat Slab Reinforcement-1.pdf
 Filesize:  193.52 KB
 Downloaded:  395 Time(s)
$sf.rar
Safe file-3
 Filename:  $sf.rar
 Filesize:  6.09 KB
 Downloaded:  345 Time(s)
.F2K.rar
Safe file-2
 Filename:  .F2K.rar
 Filesize:  2.24 KB
 Downloaded:  326 Time(s)
.FDB.rar
Safe file-1
 Filename:  .FDB.rar
 Filesize:  630.98 KB
 Downloaded:  441 Time(s)
chandra_s_eng
PostPosted: Wed Nov 09, 2016 5:52 pm    Post subject: This is too bad. Reply with quote
Not even single reply from anyone.
bhsolanki
PostPosted: Wed Nov 16, 2016 7:17 am    Post subject: Reply with quote
Hello Chandra,
I will reply you on next week on your query.
