Semi Circular Cantilever Stair Case
chockalingam
PostPosted: Thu Sep 07, 2017 3:07 pm    Post subject: Semi Circular Cantilever Stair Case Reply with quote
Hello SEFIans
Greetings from Chockalingam
Good evening. Hereby I am in need of a small favor. How to design the semi circular cantilever stair? Anybody, please tell me how to proceed in this regard? Thanks in advance. Thank you.
PostPosted: Fri Sep 08, 2017 4:39 am    Post subject: Reply with quote
Dear SEFIan,
Please post the diagrams of your staircase.
sasindran_s
PostPosted: Sat Oct 07, 2017 8:05 am    Post subject: Re: Semi Circular Cantilever Stair Case Reply with quote
Hi,
Please note that API code 650 (design of tanks) is having a procedure for designing the steel circular staircase. The staircase is designed as being supported from the shell of the tank and partially being supported by hanging through the handrail.
If you dont want to adopt this ideology you may design each step as being supported by the central column. Dont forget to consider the handrail load.
w.r.t the placing of the steps its better to draw a preliminary sketch in order to find the length available for welding at the central column. It will help you to determine the diameter of the central column as well. In case if you dont have enough space available for the weld, please increase the welding space at the support location by extending the step at support location. Refer the AutoCAD file attached.
Sasindran S
chockalingam wrote:
Hello SEFIans
Circular stair-plan.rar
 Filename:  Circular stair-plan.rar
 Filesize:  32.46 KB
 Downloaded:  66 Time(s)
