Minimum diameter
yogeendraholebagilu
PostPosted: Wed Oct 11, 2017 9:49 am    Post subject: Minimum diameter Reply with quote
Dear all,
What is the minimum diameter of bar that can be used for stirrups in PSC beams according to IS code??
kunalkansara
PostPosted: Tue Oct 17, 2017 5:30 pm    Post subject: Reply with quote
Dear Engineer
It depends upon what size longitudinal rebars you are intending to contain within stirrup links.
IS1343-2012 suggests in cl. 23.4.3.2: In rectangular beams, at both corners in the tensile zone, a stirrup should pass around a longitudinal bar, a tendon or a group of tendons having a diameter not less than
the diameter of the stirrup.
Hope this helps!
Kunal
spsvasan
PostPosted: Thu Oct 19, 2017 4:14 am    Post subject: Reply with quote
kunalkansara wrote:
Dear Engineer
Hope this helps!
Kunal
Dear Er.Kunal Kansara
I think the clause indicated above is meant for the minimum size of the longitudinal corner reinforcement.
I think IS 1343 does not specify a minimum diameter for stirrups.
In many sites, 6mm bar is not used, since these are not manufactured by reputed manufacturers. In some major sites, 8mm bars are also disallowed.
S.P.Srinivasan
