etabs design options
rajeshpullat
PostPosted: Sun Oct 22, 2017 2:28 am    Post subject: etabs design options Reply with quote
Hi
in etabs there are 3 design options in design overwrites...ductile, ordinary and non sway
what is the difference between these
Rajesh
sakumar79
PostPosted: Sun Oct 22, 2017 6:47 am    Post subject: Reply with quote
Dear Er Rajesh,
     The default option is Ductile which designs the members (columns, beams, walls, etc) as as per relevant code for Ductile Detailing (IS 13920 in Indian code). Ordinary designs the members without Ductile Detailing. Non-sway option instructs the software to neglect the check for sway frame.
Yours sincerely
S Arunkumar
rajeshpullat
PostPosted: Mon Oct 23, 2017 2:37 pm    Post subject: option to be used Reply with quote
Hi
thanks for your reply
Which option should we use for design...please tell me the occasion where we use a particular option
Rajesh
logeshcivil
PostPosted: Thu Dec 06, 2018 6:24 am    Post subject: Design options Reply with quote
Dear sefians
How to change design option from ductile to ordinsary in etabs 2016
Thank you in advance
Yours
Er. S.Logesh
sakumar79
PostPosted: Sun Dec 09, 2018 5:06 am    Post subject: Reply with quote
    After analysis, select the members and in Concrete Design menu, go to View/Revise Overwrites. Here, the second option (if I remember correctly) is Element Type. You can set this as Ductile, Ordinary and NonSway. You should set Ductile (default) when detailing as per IS13920. You can use Ordinary if you are not doing Ductile Design. Nonsway option can be adopted if your frame is Nonsway and you are not doing Ductile design.
Hope that helps
Arunkumar
logeshcivil
PostPosted: Mon Dec 10, 2018 3:44 am    Post subject: ETABS Reply with quote
Dear  Arun Kumar
Thank you
It is indeed a helpful reply
Yours
Er.S.Logesh
