Retaining wall
ramu_se
PostPosted: Thu Nov 09, 2017 7:49 pm    Post subject: Retaining wall Reply with quote
Hi All,
Can anyone please provide the manual design of all types of retaining wall
and how to design the retaining wall in staad and etabs?
Ramu
PostPosted: Fri Nov 10, 2017 3:07 pm    Post subject: Reply with quote
Er Ramu,
Don't you have the habit of referring standard text books for designs ? Almost all text books on RCC design will cover design of RCC retaining walls while soil mechanics books will cover design of masonry retaining walls.
For any retaining wall, the stability check is the first step and it is as important as structural design. This check may not be possible in STAAD. Due to the difficulty in assigning the supports to retaining walls (soil spring support can be assigned though), the structural analysis & design using STAAD is complex , I think. Hence, manual analysis & design, which is not as laborious as design of building frames, is prefarable.
ramu_se
PostPosted: Fri Nov 10, 2017 8:49 pm    Post subject: Reply with quote
Dear Jayakumar sir,
Thank you for your reply.
I do refer text books but still i just wanted to know how they are applying in actual field.Now i can understand clearly that manual design of retaining wall is much better compared to softwares.
Thank you once again.
Ramu.
PostPosted: Sat Nov 11, 2017 1:38 am    Post subject: Reply with quote
You are welcome, Er.Ramu.... While most of the advanced RCC Design books cover the design of cantilever / conterfort RCC retaining walls, the book "Brick and Reinforced Brick Structures" by Dayaratnam (Oxford & IBH) covers in detail the design of masonry retaining walls, including seismicity & stress checks.
PostPosted: Sat Nov 11, 2017 7:33 am    Post subject: Reply with quote
Further to the above, please see the attached article on the optimum design of RCC retaining walls. This includes the new concept of "Relieving Platforms", to achieve economy.
Retaining Walls - Optimal Design.pdf
 Filename:  Retaining Walls - Optimal Design.pdf
 Filesize:  6.84 MB
 Downloaded:  1666 Time(s)
ramu_se
PostPosted: Sat Nov 11, 2017 5:21 pm    Post subject: Reply with quote
Thank you very much jayakumar sir.
