ETABS 16 Strip Design
George.Philip
PostPosted: Tue Nov 14, 2017 1:30 pm    Post subject: ETABS 16 Strip Design Reply with quote
I have been designing a flat slab using ETABS. I have drawn strips and when comparing the strip moments and the strip based design, the reinforcement area obtained are much larger than it should be. Is there anyone faced the same problem? Could anyone clarify this?
arunangshu
Progressive Member
Progressive Member
PostPosted: Tue Nov 14, 2017 10:14 pm    Post subject: Reply with quote
Dear George,<o></o>
A similar discussion going on in LinkedIn (https://www.linkedin.com/groups/2983130/2983130-6330328396933009409).<o></o>
I think the first point would be comparing the design forces and then investigating the differences (in design output) rather than directly jumping into conclusions.<o></o>
For a better comparison, hinge the columns at slab junction to prevent moment transfer and then check the punching shear ratios; and before performing design make sure that the design parameters are exactly same. Also make sure that, your models are free from 'stiffness modifiers'.<o></o>
Above exercise will help to converge the issue and we can have further discussion.<o></o>
Cheers!<o></o>
Arun
