Min bar dia for Main tension reinf.- Design of Reinforced Concrete Structure by N. Subramanian
hishamajmalpc
PostPosted: Mon Nov 27, 2017 8:18 am    Post subject: Min bar dia for Main tension reinf.- Design of Reinforced Concrete Structure by N. Subramanian Reply with quote
Dear sefians,Is there any min dia for  tension rebars?The bellow textbook states a min dia of 12mm for tension bars in chapter 5 para4.     Design of Reinforced Concrete Structures           by N. Subramanian plz clarify:...
abhishek_ecs
PostPosted: Sun Dec 03, 2017 5:15 pm    Post subject: Reply with quote
I dont think the code specifies any min dia for bars,but it is governed more by consideration of spacing and practical utility.Minimum Spacing for bars is specified by the code that indirectly limits the bar diameter.Also, Less diameter if bars means more no of bars means more crowding ,less spacing which will finally lead to difficulty in placing them.
I remember  being advised by Prof. A.K.Jain (who wrote the famous book Limit state design) during my graduation years to not choose less than 12mm dia bars even in solving problems, because additional check for min spacing needs to be carried out.
mainak.mallik
PostPosted: Tue Dec 05, 2017 4:24 am    Post subject: Reply with quote
Please note as per clause 6.3 of SP 34 minimum diameter of main reinforcing bar is 10mm. However for concrete structure in contact with soil it is advisable to use 12mm diameter bar.
