Corrosion of column rebars
pallavi23
PostPosted: Tue Dec 19, 2017 9:20 am    Post subject: Corrosion of column rebars Reply with quote
Hello! I face this problem very often. Many people constructing their homes generally leave column rebars in open for purpose of future construction. These column rebars over a period of time corrode due to atmospheric conditions. In such a case, what is the best remedy to overcome this problem?
B.V.Harsoda
PostPosted: Tue Dec 19, 2017 12:13 pm    Post subject: Re: Corrosion of column rebars Reply with quote
Er. Pallavi,
You are right. The solutions for this problem  are
1. Rebars shall be covered with cement slurry and maintain this  coating  from damage.
2. Concrete casting  is best solution, it will also help to resist moment at beam column joint.
Best Wishes,
Er. B. V. Harsoda
pallavi23
PostPosted: Wed Dec 20, 2017 4:49 am    Post subject: Re: Corrosion of column rebars Reply with quote
Thanks for the reply sir. But what to do in case the rebars have corroded? How do we start the construction?
B.V.Harsoda wrote:
Er. Pallavi,
Best Wishes,
Er. B. V. Harsoda
B.V.Harsoda
PostPosted: Wed Dec 20, 2017 7:10 am    Post subject: Reply with quote
Use RUSTICIDE Rust Remover and Passivator & follow instruction by manufacturer to remove rust from rebars
RUSTICIDE is a single component sulphate and chloride free liquid, which in one operation removes rust and prevents further rusting of steel.
APPLICATIONS Removes rust and prevents further rusting of
New/ old reinforcement steel in new construction.
Embedded steel in repairable structures.
Various steel structures like tanks, water pipelines, effluent pipelines, trusses, purlins, rafters and other structural members.
ADVANTAGES
RUSTICIDE performs rust removal and rust prevention in one operation in mild conditions.
Link:-
http://www.sunandaglobal.com/site/wp-content/themes/rttheme6/pdf/Corrosion%20Protection/Rusticide.pdf
B.V.Harsoda
PostPosted: Wed Dec 20, 2017 7:12 am    Post subject: Reply with quote
Follow the below IS Code Als0
 Filesize:  84.12 KB
 Viewed:  196 Time(s)
pallavi23
PostPosted: Wed Dec 20, 2017 8:53 am    Post subject: Reply with quote
Thanks a lot sir.
ADVANTAGES
Link:-
