A underground circular base slab (Well design)
sheethal
PostPosted: Sat Jan 06, 2018 6:54 am    Post subject: A underground circular base slab (Well design) Reply with quote
Dear Sir/Madam,
Can anybody explain how to design a underground circular base slab?
Im designing a underground circular water tank manually, I got the reference for designing circular wall but I'm not getting reference to designing underground circular base slab. can anybody send the design for the same?
PostPosted: Sun Jan 07, 2018 11:30 am    Post subject: Reply with quote
Dear Er.Sheetal,
You can design the base slab of a UG circular water tank using the formulae for calculating the BMs of a circular slab. In tank empty case, you calculate the total weight of the peripheral walls and the covering slab and divide it with the area of base slab to get the upward reaction in kN/m2. The weight of the base slab need not be taken into account, as it is directly supported on ground. If there is possiblilty for the ground water level to rise above the bottom of the base slab, you have to add the upward thrust due to this hydrostatic force also, which is equal to density of water X height of ground water level above the bottom of the base slab. You can use fixed edge conditions for the base slab design, which can account for the moments at the edge due to the slab projection also.
sheethal
PostPosted: Mon Jan 08, 2018 7:39 am    Post subject: Reply with quote
Thank you Sir.,
What should we do for the tank full condition?
Is there any effect of earth pressure on base wall?
How to consider the value of q while calculating Mr and Mt for these two condition.
PostPosted: Tue Jan 09, 2018 3:10 pm    Post subject: Reply with quote
Er Sheethal,
The tank full condition is needed to be considered while designing the side walls (tank full and no earth pressure from outside - during testing leakage). But, when it comes to the design of bottom slab, the pressure from stored water need not be considered, as the same is getting directly supported on earth through the bottom slab. The vertical moment at the bottom of side wall due to earth & water pressure during submergernce can have effect on the base slab edge radial moment. Hence, the fixed condition may be assumed for the edge of the circular base slab. You can refer Example 10.4 in the book "Design of Reinforced Concrete Structures" by M.L.Gambhir (PHI). This is the case of a circular tank resting on ground. Here, partially fixed condition is assumed for the base slab. The design UD area load q may be worked out taking into account the weight of side walls, covering slab and hydrostatic thrust as already indicated above. It is advisable to ensure some minimum nominal steel at top and bottom, throughout the base slab.
sheethal
PostPosted: Tue Jan 16, 2018 11:02 am    Post subject: Reply with quote
Thank you Sir.
I have attached an excel sheet of underground circular water tank, If there is any corrections let me know.
This might be helpful for others.
-Sheethal
underground circular tank R2.xlsx
 Filename:  underground circular tank R2.xlsx
 Filesize:  106.25 KB
 Downloaded:  360 Time(s)
