ECONFERENCE ON TALL CONCRETE BUILDINGS- IS 16700:2017
chandramohan R.S
PostPosted: Tue Mar 13, 2018 6:27 am    Post subject: ECONFERENCE ON TALL CONCRETE BUILDINGS- IS 16700:2017 Reply with quote
DEAR SIR/MADAM,
KINDLY CLARIFY THE FOLLOWING.
1.PL. REF. TO CL 5.6.3. IN THIS IT IS STATED THAT " NATURAL VERTICAL
VIBRATION FREQUENCY OF ANY FLOOR SYSTEM SHALL NOT EXCEED 3 HZ....." MY
QUESTION IS HOW TO WORK OUT THE FRQUENCY OF FLOOR SYSTEM? WHETHER WE
HAVE TO MODEL THE FLOORS, AND CARRY OUT TIME HISTORY ANALYSIS? IF SO
WHAT SHOUD BE THE INPUT TIME HISTORY?
2.AGAIN CL.5.6.4 SAYS "UNDER GRAVITY LOADS PEAK VERTICAL
ACCELERATION....." HOW TO WORK OUT THE ACCELERATION VALUES FOR EACH
FLOOR UNDER GRAVITY LOADS?
3. 6.2.1 " FOR BUILDINGS... IN OUR COUNTRY WHETHER EXPERTS ARE
AVAILABLE FOR CONDUCTING WIND TUNNEL  STUDIES?ARE THERE LABORATORIES
AVAILABLE FOR BUILDINS? IF SO PL. GIVE DETAILS.
4. CL6.2.3 PERMISSIBLE PEAK ACCELERATION ARE SPECIFIED IN TABLE4. I
UNDERSTAND THAT THESE VALUES CAN BE OBTAINED ONLY FROM WIND TUNNEL
STUDIES. OR IS THERE ANY ANALYTICAL METHOD. PL. CLARIFY
5. TABLE 5. MINIMUM DESIGN BASE SHEAR COEFFICIENT: FOR DIFFERENT ZONES
VALUES ARE SPECIFIED. IN IS1893:2016 SAME VALES ARE GIVEN IN TABLE7,
BUT IN 1893 IT IS MENTIONED AS "PERCENTAGE", I SUPPOSE HERE ALSO IT IS
THE SAME. IF SO IT IS "PERCENTAGE" OF WHAT? IS IT WEIGHT OF STRUCTURE
INCLUDING DEAD+LIVE?
I REQUEST YOU TO CLARIFY THE ABOVE POINTS.
CHANDRAMOHAN.R.S
Confidentiality Notice: This e-mail message, including any attachments,
is for the sole use of the intended recipient(s) and may contain
confidential and privileged information. Any unauthorized review, use,
disclosure or distribution is prohibited. If you are not the intended
recipient, please contact the sender by reply e-mail and destroy all
copies of the original message.
abhio
PostPosted: Tue Mar 13, 2018 7:03 am    Post subject: Reply with quote
I believe this is an error in the Code. The 3 Hz limitation ought to be a lower bound, and not upper bound on the natural frequency of the floor.
As for your query, Er. Chandramohan, please refer to
https://www.steelconstruction.info/Floor_vibrations
and
http://nptel.ac.in/courses/105106113/2_industrial_building/3_industrial_floors.pdf
for ways to estimate the natural frequency of the floor.
A S Oundhakar
hemalmistry
PostPosted: Tue Mar 13, 2018 7:12 am    Post subject: Reply with quote
Many software have facility to perform vibration analysis (including footfall vibration). We can get natural vertical vibration frequency for particular floor or for required portion of floor. Acceleration can be worked out with some formulation using frequency and other parameter. However, according to ATC guidelines to check human sensitivity to floor vibration for particular use of floor, a particular combination of frequency and acceleration shall be checked as attached here.
IS:16700-2017 have specified limit for acceleration and frequency. However, even if frequency and /or acceleration if not within range/limit specified by IS:16700, a particular combination of frequency and acceleration may satisfy the vibration requirement of floor for particular use.
Hemal Mistry
Surat
Manoharbs_eq
PostPosted: Tue Mar 13, 2018 7:39 am    Post subject: ECONFERENCE ON TALL CONCRETE BUILDINGS- IS 16700:2017 Reply with quote
Hi
Good questions
But answers are as follows
For floor vibration study no need for input vibration only you need the load, section property and deflection.
Currently CPRI institue perform wind tunnel test also IITs do.
On Mar 13, 2018 10:31 AM, "chandramohan R.S" <forum@sefindia.org (forum@sefindia.org)> wrote:[quote]            DEAR SIR/MADAM,
CHANDRAMOHAN.R.S
dndhastak
PostPosted: Tue Mar 13, 2018 8:35 am    Post subject: ECONFERENCE ON TALL CONCRETE BUILDINGS- IS 16700:2017 Reply with quote
For Wind tunnel testing
https://www.iitk.ac.in/nwtf/index.php?option=com_content&view=article&id=5&Itemid=124r your # 3 wind tunnel testing
On Tue, Mar 13, 2018 at 12:00 PM, chandramohan R.S <forum@sefindia.org (forum@sefindia.org)> wrote:
CHANDRAMOHAN.R.S
