inchak at tatasteel.com Guest
Posted: Sat Jul 09, 2005 10:35 am Post subject: Message No 43 on TMT, Thermex and Tempcore bars |
QUESTION Dear All: What is the difference between TMT, Tempcore and Thermex reinforcement bars? In India we normally use the word TMT for all quenched and tempered bars but I believe it has a different connotation than the treatment being used in India presently. Could someone pl expand on this. Thanks, Alpa
ANSWER Thanks. This is another FAQ. and very relevant
Actually the base process has a metallurgical terminology of Thermo Mechanical Treatment (TMT). Thermex and Tempcore are both reputed trade names registered by the two major providers of this TMT technology. When PROPERLY OPERATED both Thermex and Tempcore can produce good quality TMT rebars. However, the technology of imparting online heat treatment to rapidly moving red-hot bars is quite involved and requires specialised design of equipment as well as control devices. Computerised process control is often required to dynamically adjust the many rapidly changing parameters depending on the chemical composition of the steel, the desired grade and size of the rebar etc. A makeshift arrangement, irrespective of the quantity of water used, is highly unlikely to produce the desired results.
I take this opportunity to provide some insight into the TMT process. Manufacture of high strength reinforcing steel is usually carried out through one of three alternative process routes: 1. Hot rolling after micro-alloying 2. Hot rolling followed by cold work and 3. Hot rolling followed by heat treatment (TMT). The TMT process is actually a heat treatment imparted to steel on-line just after rolling. . For the larger diameters, a small addition of micro-alloys may be resorted to. After leaving the last stand of the rolling mill, the bars are quenched (rapidly cooled) in water from a final rolling temperature of about 950 Deg. C. The quenching is partial - only until a surface layer has been transformed from austenite (a steel phase stable only at very high temperatures) to martensite (a steel phase stable at ambient temperatures). This controlled quenching is achieved in one or more specially designed on-line water cooling devices through which the steel passes at a very high speed before reaching the cooling bed. Because the quenching is only partial, a significant part of the original heat remains in the core of the bar and, on the cooling bed, this heat migrates towards the surface. This results in an automatic self-tempering process where the surface layer of martensite is tempered. This "tempering temperature" (or equalisation temperature) refers to the maximum temperature attained by the surface of the bar after quenching. Tempering enables a partial diffusion of carbon out of the extremely brittle but strong martensite, thus relieving the inherent stresses locked in during the sudden quenching of the red-hot steel in cold water. The resulting tempered-martensite shows improved ductility and toughness compared to the as-quenched martensite. Due to inherent characteristic of the quenching and self-tempering (QST) process, the product retains its properties to temperatures lower than this self-tempering temperature. The core of the heat-treated rebars consists of ferrite and pearlite - which is not cold worked and is therefore quite tough. In general, when the TMT process is carried out properly the resulting product has a much higher level of both strength and ductility with a much lower carbon equivalent than is normally attained by the cold working processes like CTD. The fine martensitic microstructure at the surface also ensures improved resistance to corrosion, which has been measured to be about 30% higher than the cold twisted material. While the cold twisted material looses it tensile strength rapidly on heating about 350deg.C because the annealing action sets in, the TMT bars are stable up to a temperature of at least 550 Deg. C, a temperature at which is tempered. This accounts for a much better fire resistance to the structures made with TMT bars.
********************************DISCLAIMER*********************************** Information contained and transmitted by this e-mail is confidential and proprietary to Tata Steel Ltd. and is intended for use only by the addressee. If you are not the intended recipient , you are notified that any dissemination or copying of this e-mail is strictly prohibited and you are requested to delete this e-mail immediately and notify the originator. Tata Steel does not enter into any binding agreement with any party by e-mail. Any views expressed by an individual do not necessarily reflect the view of Tata Steel. Tata Steel is not responsible for the consequences of any actions taken on the basis of information provided. While this e-mail has been checked for all known viruses the addressee should also scan for viruses. To know more about Tata Steel please visit www.tatasteel.com ********************************************************************************
