clause 6.2.2.4_damping ratio
hemalmistry
PostPosted: Tue Mar 13, 2018 6:42 pm    Post subject: clause 6.2.2.4_damping ratio Reply with quote
Clause 6.2.2.4 requires damping ratio of 2% for concrete. Design acceleration spectrum as per IS 1893-1_2016 is for 5% damping. Which spectrum shall be used for 2% damping as per IS 16700?
IS 1893-1_2002 was having multiplying factor for dampling other than 5%.
Hemal mistry
Surat
bsec
PostPosted: Wed Mar 14, 2018 5:02 am    Post subject: clause 6.2.2.4_damping ratio Reply with quote
Dear Hemal,
I think 2% damping is for wind analysis and not for seismic analysis. For seismic analysis the spectrum is with 5% damping. Difference is possibly due to the philosophical difference in treatment of wind and seismic loads for design. Building is supposed to remain elastic with characteristic Wind load, while the building is allowed to go into in-elastic range under seismic loads.
Best Wishes
Alok Bhowmick
On Wed, Mar 14, 2018 at 12:12 AM, hemalmistry <forum@sefindia.org (forum@sefindia.org)> wrote:
Hemal mistry
Surat
indrajit-chowdhury
PostPosted: Wed Mar 14, 2018 5:14 am    Post subject: clause 6.2.2.4_damping ratio Reply with quote
I would multiply the response spectrum value Sa/g furnished in code by a factor sqrt ( 10/7) to arrive at value for 2 % damping.
On 14 Mar 2018 10:14 am, "hemalmistry" <forum@sefindia.org (forum@sefindia.org)> wrote:
Hemal mistry
Surat
alpa_sheth
PostPosted: Wed Mar 14, 2018 5:27 am    Post subject: clause 6.2.2.4_damping ratio Reply with quote
You are right, Alok. 2% damping is only for wind loads. Seismic stays at 5%, you have articulated the philosophy.
regards,
Alpa
On Wed, Mar 14, 2018 at 10:32 AM, bsec <forum@sefindia.org (forum@sefindia.org)> wrote:
[quote]            Dear Hemal,
Best Wishes
Alok Bhowmick
On Wed, Mar 14, 2018 at 12:12 AM, hemalmistry forum@sefindia.org (forum@sefindia.org))> wrote:
alpa_sheth
PostPosted: Wed Mar 14, 2018 5:45 am    Post subject: clause 6.2.2.4_damping ratio Reply with quote
I think we should not mix apples and oranges. As Senior Designer Alok Bhowmick has already explained, you are working in elastic range in Wind loads and in the in elastic range in Earthquake loads.
5% damping for earthquake loads and use IS 1893 spectrum. No scaling etc is required.
best regards,Alpa Sheth
VMS Consultants Pvt. Ltd.
83 Sakhar Bhavan
230 Nariman Pt.
Mumbai 400021
Tel: 91-22-61725200
w (vmsb@vakilmehtasheth.com)ww.vakilmehtasheth.com
On Wed, Mar 14, 2018 at 10:47 AM, indrajit-chowdhury <forum@sefindia.org (forum@sefindia.org)> wrote:
[quote]            I would multiply the response spectrum value Sa/g furnished in code by a factor sqrt ( 10/7) to arrive at value for 2 % damping.
On 14 Mar 2018 10:14 am, "hemalmistry" forum@sefindia.org (forum@sefindia.org))> wrote:       --auto removed--
hemalmistry
PostPosted: Wed Mar 14, 2018 5:57 am    Post subject: Reply with quote
Alpa mam, alok sir,
Thanx for the clarification. I think it should be mentioned in amendment of IS:16700 that 2% damping is for wind load.
hemal
Gangisetty Krishna
PostPosted: Wed Mar 14, 2018 6:29 am    Post subject: Re: clause 6.2.2.4_damping ratio Reply with quote
Alok Sir,
I have gone through the literature regarding the tall structure damping ratio. In the document PEER/ATC72-1 in section 2.1.3 that the damping is substantially different from values typically assumed in low rise building. Is there any chance of changing the damping ratio of the concrete building to 2% for tall building in future amendments.
bsec wrote:
Dear Hemal,
Best Wishes
Alok Bhowmick
Hemal mistry
Surat
SACHINbidar
PostPosted: Wed Mar 14, 2018 6:53 am    Post subject: clause 6.2.2.4_damping ratio Reply with quote
MamWhy IS 16700 doesn't cover structures with steel
On 14-Mar-2018 11:17 AM, "alpa_sheth" <forum@sefindia.org (forum@sefindia.org)> wrote:
]https://drive.google.com/uc?id=0B4BXntATUzLzTWdET1NuSmJtUTA&export=download">
83 Sakhar Bhavan
230 Nariman Pt.
Mumbai 400021
Tel: 91-22-61725200
w (vmsb@vakilmehtasheth.com (vmsb@vakilmehtasheth.com))ww.vakilmehtasheth.com
On Wed, Mar 14, 2018 at 10:47 AM, indrajit-chowdhury forum@sefindia.org (forum@sefindia.org))> wrote:
On 14 Mar 2018 10:14 am, "hemalmistry" forum@sefindia.org (forum@sefindia.org) (forum@sefindia.org (forum@sefindia.org)))> wrote:       --auto removed--
imteyaz_ahmad
Clause 7.3.11 is in contradiction with Table 1 in Section 5, which prohibits use of flat slab in Zone IV & V. But 7.3.11 says to ignore ignore stiffness of flat slab. Code should be consistent with its provisions, one can be confused to use whether use flat slab system or not in those zones.
On 14 March 2018 at 00:12, hemalmistry <forum@sefindia.org (forum@sefindia.org)> wrote:
Hemal mistry
Surat
sangeeta_wij
Yes Hemal, but you are right that we will then need to carry out two separate sets of analysis, one with Wind and 2% damping and the second with Seismic and 5% damping and then select the governing one for each member.For large and complicated structures, it really will be a challenge unless ETABS comes up with a better way forward!
Best Regards
Sangeeta Wij
President,WISE India
Managing Partner
SD Engineering Consultants LLP
Vice President(North),Indian Association of Structural Engineers,
Fellow and Chartered Engineer, Institution of Engineers
H333 New Rajinder Nagar(Lower Ground Floor),
New Delhi-110060
Ph:9811776210;01145128530
Sent: 14 March 2018 11:27
To: econf@sefindia.org
Subject: [E-CONF] Re: clause 6.2.2.4_damping ratio
Alpa mam, alok sir,
hemal
