clause 8.1.3.3.1 and clause 9.6
hemalmistry
PostPosted: Wed Mar 14, 2018 6:59 pm    Post subject: clause 8.1.3.3.1 and clause 9.6 Reply with quote
Clause 8.1.3.3.1 permits to exclude backstay effect for tall buildings with seismic joint between tower and podium. However, clause 9.6 requires to avoid expansion joint in basement of tall building. Does it meen that seismic joint can be provided but expansion joint can not be provided?
pushpinder84
Progressive Member
Progressive Member
PostPosted: Sat Mar 17, 2018 5:42 am    Post subject: Reply with quote
Clause 9.6 refers to the expansion joints within the building as opposed to the separation joint between the building and the podium. Closing of this joint will result in analysis similar to 8.1.3.3.3 (towers connected by podium) and not 8.1.3.3.1.
Pushpinder Chauhan
