Compression and Tension Development Length
Er.Ajith_K
PostPosted: Tue Jun 05, 2018 6:48 pm    Post subject: Compression and Tension Development Length Reply with quote
Hi,
I would to clarify regarding compression and tension development length. Which rod in a beam is considered as compression and tension for calculating development length ? In some source, top rod is considered as tension so tension development length is provided for top rod and in another source, bottom reinforcement is considered as tension to calculate tension development length. Please kindly clarify my doubt.
I also have another question, I have seen a engineer providing 90 degree bend for top reinforcement and straight bar for bottom reinforcement. Is it acceptable practice ?
With Regards
Ajith Karunanithi
Thankful People
Shahid Goundi
PostPosted: Mon Jun 11, 2018 5:40 am    Post subject: Reply with quote
Dear Er Ajith
Usually top bars are subjected to tension due to hogging bending moment at support hence development length for tension is provided for top bars.
And during earthquake both top and bottom bars will be subjected to tension due to cyclic loading. Hence it is recommended to provide 'Ld' in tension for both top and bottom bars.
For the second question: Usually for Beams at ends are provided with 90 deg Bends for both top and bottom bars depending upon the size for column , and bar are provided straight over continuous support. You can refer SP-34 (Section 8 for beams) for typical detailing of Continuous beam
Hope I am helpfull
Thanks and Regards
Mohd Shahid Goundi
Structural Engineer
