STAAD TO ETABS
prav_77
PostPosted: Fri Jan 24, 2014 6:44 am    Post subject: STAAD TO ETABS Reply with quote
HELLO SEFIANS,
  I m new to etabs and i want to export staad file to etabs. i was able to do only geometry but not loading and property..    please help me out here...
sakumar79
PostPosted: Fri Jan 24, 2014 7:12 am    Post subject: Reply with quote
Hi,
   You can open ETABS, go to File->Import and choose GT STRUDL/ STAAD file and use it to import staad file.
   If your staad model has floor loads, it is suggested that you comment them out and import without those loads and then add the slab panels to the ETABS model and apply loads to them.
   Generally, the model including loads and properties will get imported. It will be necessary to define the floor grid system and storey levels to navigate the geometry in ETABS.
Hope that helps.
Arun
prav_77
PostPosted: Fri Jan 24, 2014 7:30 am    Post subject: Reply with quote
thanks for helping.. can i ask how wud u define grid system when it is complicated building..
u mean to say first i import architecture grid and then import the staad file without floor loads..  m i correct?
sakumar79
PostPosted: Fri Jan 24, 2014 12:50 pm    Post subject: Reply with quote
If the grid system is complicated you can import it from dxf file... Otherwise, you can create the grid lines manually in ETABS directly. Make sure the grid system being defined matches with the staad geometry.
Arun
prav_77
PostPosted: Fri Jan 24, 2014 4:52 pm    Post subject: Reply with quote
thanks a lot.. it really helped Smile
vineetaggarwal
PostPosted: Fri Jun 29, 2018 10:01 am    Post subject: ETABS to STAAD HOW to ? Reply with quote
Any software to convert data of one structural package to another ? Currently, I need to know how to convert ETABS data file (without having ETABS software) to STAAD file ? Any help would be welcome.
