column design
ramu_se
PostPosted: Mon Aug 06, 2018 4:03 pm    Post subject: column design Reply with quote
Hi all,
How to find out whether the column is axially loaded, axial load with uniaxial bending and axial load with bi-axial bending from floor plans?
Thank you
Ramu.
syed_A
PostPosted: Tue Aug 07, 2018 4:12 am    Post subject: Reply with quote
Dear Engineer
Depends on loading like concentric and eccentric, One may assume all corner columns as Biaxial, Edge columns Uni axial and internal as Axial.If you are familiar with any analysis software for civil engineers, can check by modeling a simple plan with DL and LL. Hope this helps
ramu_se
PostPosted: Tue Aug 07, 2018 12:10 pm    Post subject: Reply with quote
Thank you sir.
I had done modelling in staad.pro and iam getting moments in internal columns too.Can you please check the model.
Structure1.zip
 Filename:  Structure1.zip
 Filesize:  8.61 KB
 Downloaded:  216 Time(s)
syed_A
PostPosted: Tue Aug 07, 2018 2:32 pm    Post subject: Reply with quote
It is not necessary all internal columns carry only axial load, analysis is the best option to arrive/conclude behavior of member/column. Further you can minimize the moments by checking or orientation of column with beta angle command
good luck
ramu_se
PostPosted: Tue Aug 07, 2018 7:09 pm    Post subject: Reply with quote
Thank you sir.
i hope when columns and beams are not integrally connected,it is subjected to axial load.
Middle columns in the end row are subjected to uniaxial bending and corner columns are subjected to biaxial bending.
Please correct me if iam wrong.
Thanks,
Ramu.
