Minimum Design Earthquake Horizontal Lateral Force in Table 7 in IS 1893-2016
Mohammad Jinya
PostPosted: Tue Aug 07, 2018 2:48 pm    Post subject: Minimum Design Earthquake Horizontal Lateral Force in Table 7 in IS 1893-2016 Reply with quote
Dear sefians,
I am not understand regarding in percent as given in Minimum Design Earthquake Horizontal Lateral Force in Table 7 in IS 1893-2016.
Please help me for better understand.
Thank you.
ychodneker
PostPosted: Mon Sep 03, 2018 3:30 am    Post subject: Min Eq design force as per IS 1893:2015 Reply with quote
Even I have same question. Please can help understand this term.
sakumar79
PostPosted: Mon Sep 03, 2018 7:34 am    Post subject: Reply with quote
    The base shear is calculated as Ah. W. The minimum value of Ah is given as a percentage in the mentioned table. For example, Ah should not be less than 0.7% or 0.007 in Zone II.
For example,
Consider Z=.1 (Zone II), I=1, R=5. If Time Period is long, Sa/g may be around 0.5. Then, Ah will be .1/2 x 1/5 x 0.5 = 0.005 - In such a case, we should take it as 0.007 instead.
Hope that helps.
Yours sincerely
Arunkumar
FARA
PostPosted: Fri Jul 05, 2019 12:40 pm    Post subject: Reply with quote
sakumar79 wrote:
For example,
Hope that helps.
Yours sincerely
Arunkumar
How to enhance from 0.005 to 0.007 in ETABS ?
What procedure shall be adopted to care of this.
sakumar79
PostPosted: Wed Jul 10, 2019 11:24 am    Post subject: Reply with quote
    I think the simplest way is to change I value so that Ah gets boosted to the required minimum. For example, in the above case, Ah has to be boosted from 0.005 to 0.007 (40%). Hence, if I is revised from 1 to 1.4, the minimum Ah will get applied automatically.
   Another alternative is to adjust the load factor in EQ load combinations but this will be more tedious.
   Other experienced engineers with simpler or better ideas may please give their views also.
Yours sincerely
S Arunkumar
