Suggest the Problem (structural Engineer ) :which can be sort out by research work
Ravikumar
PostPosted: Fri Aug 17, 2018 5:43 am    Post subject: Suggest the Problem (structural Engineer ) :which can be sort out by research work Reply with quote
Hi , My respected structural engineers, Actually I plan  to do PhD in Structural Engineering ..as full time reseaso regarcher so kindly could you people  suggset anyimportant topic currentt issues in Structural Engineering in prac tice ) ,In which we  need  a research work ...so leasee suggest those problem which will help me to do start the research work in it
Thankful People
PostPosted: Fri Aug 17, 2018 7:58 pm    Post subject: Re: Suggest the Problem (structural Engineer ) :which can be sort out by research work Reply with quote
Dear Er Ravi Kumar
The area you want to work for your Ph. D. Depends on the institution you are going to work and the facilities available there and also your guide and his expertise in a particular field.
Decide on the above two and select a subject based on the suggestions of your guide and not on us.
bkkk
PostPosted: Mon Aug 20, 2018 12:47 pm    Post subject: Doctoral course -Reg. Reply with quote
Dear sefian
Dr.Subramanian sir has rightly pointed out that your doctoral course depends upon  your 1. Institutional facilities  2. Competence of your guide 3. Your personal interest.
First arrive at the broad area of your  research , and  find out the academic experts who can guide you  and on consultation with him you can arrive at an area of research. You can change the proposed topic without any major deviation even after your course work. You can also decide whether your proposed research work is data based or experiment based depending upon your area of interest and facilities available at the research center proposed  by you for your research.
More than above all you personal  to carry out meaningful research in the chosen topic is the key yo success.
Good luck
Regards.
Dr.venkat ME Ph.D.
