Unsupported Length of Columns Supporting Overhead tanks
KartikMahajan
PostPosted: Thu Sep 13, 2018 9:09 am    Post subject: Unsupported Length of Columns Supporting Overhead tanks Reply with quote
Sir,
Q.1. Referring to Fig. 5, pg 16, IS 11682:1985, Unsupported length of columns at section B-B is given as total length up to the bottom of tank portion. But, in plan section B-B shown is not orthogonal to other section A-A. This situation arrives in all type of staging columns where columns are braced only by peripheral beams. When exactly do we need to take the unsupported length of the column as shown in section B-B ?
Q.2. If column (let's say staging column of a overhead tank) is braced with beams in two orthogonal directions then the unsupported length of it is as per Clause 25.1.3, pg 42, IS 456:2000. But, if it's not the case, means if column is braced with beams in two directions but not orthogonal to each other, what will be the unsupported length ?
Q.3. Is there any co-relation between clauses mentioned in above two questions ?
(Solved Examples, if available, are most welcome.)
Thanks and best wishes,
Kartik Mahajan
