Various sized vertical rebars in one shear wall or column
niresh28
PostPosted: Fri Jan 04, 2019 1:40 am    Post subject: Various sized vertical rebars in one shear wall or column Reply with quote
Is it a normal practice to have rebars with different sizes in a single shear wall or column?
For instance, the main rebar is T32 @ 200mm spacing. And also added are T16 @ 200mm spacing (refer cross section attached).
Is there any factors to be considered for adopting multiple rebar sizes within the same shear wall/column?
Thank you, your input is highly appreciated.
 Filesize:  19.06 KB
 Viewed:  73 Time(s)
