meerameen SEFI Member
Posted: Thu Aug 11, 2016 4:16 am Post subject: Shear wall design in a multi storied building |
Dear sir,
I have to design a ahear wall in staad pro. Since shear wall is continous from foundation to roof . How can i model it in staad without floor beams in the middle.
Kindly suggest. |
syed_A ...
Posted: Thu Aug 11, 2016 11:15 am Post subject: |
Post your model sketch to have an idea / understand easily |
Posted: Thu Aug 11, 2016 11:40 am Post subject: Shear wall design in a multi storied building |
Sir,
Kindly find the plan picture of the project.its a g+7 storey building. Assume all beams and columns are same size. And slan 125 mm thick. Shearwall 250 mm.
Total 8 shear walls. 4 at the coners . 2.5m each and 4 at staircase 1.235m each. Hw should i model this plan. Since shearwall is through wall from basement to roof. No beam comes above it in each floor level. I have watched videos in which beam is placed above shearwall at floor level.i think its a wrong practise. |
syed_A ...
Posted: Thu Aug 11, 2016 4:59 pm Post subject: |
Dear Engineer
First model the structure as per your requirement/dimensions
Then add shear wall at four corners using surface elements and also for staircase area. Select all the beams by switching to front view,add auto generation of plates as slab with required thickness
lastly delete the columns/beams where ever your shear wall presents
Use translation command to generate number of floors
Finally assign properties,supports,loads , analysis and design command with necessary parameters...Done
I cannot say about those shear wall tutorials, whether correct or wrong
good luck |
podianu1 SEFI Member
Posted: Wed Dec 12, 2018 8:56 am Post subject: |
Do you need shear walls, rather than straight away giving them, examine if its required, in fact suggest you increase the thickness of component members for economy. |
