change of roof (from flat to sloped) of a building
anurag.sinha
PostPosted: Mon Oct 29, 2018 7:30 am    Post subject: change of roof (from flat to sloped) of a building Reply with quote
In case the RCC Roof of a building changes from flat roof (as per bid/ tender awarded to the contractor) to 1:3 sloping roof (as per construction drawing issued to the contractor), what claims can the contractor have due to the change of roof from flat to sloped?
Regards, | सादर,
Anurag Sinha | अनुराग सिन्हा
****** SAVE A TREE ******
Please print only when necessary; avoid unnecessary prints and save the environment.
The Mail has been scanned by McAfee Appliance
*****************DISCLAIMER**********************
“The contents of this E-mail (including the contents of the enclosure/(s) or attachment/(s) if any ) are privileged and confidential material of ENGINEERS INDIA LIMITED (EIL) and should not be disclosed to, used by or copied in any manner by anyone other than the intended addressee/(s). If this E-mail (including the enclosure/(s) or attachment/(s) if any ) has been received in error, please advise the sender immediately and delete it from your system. The views expressed in this E-mail message (including the enclosure/(s) or attachment/(s) if any) are those of the individual sender, except where the sender expressly, and with necessary authority, states them to be the views of EIL.”
PostPosted: Mon Oct 29, 2018 5:03 pm    Post subject: Reply with quote
If you go by CPWD DSR (Delhi Schedule of Rates), the rate of RCC for roofs of slope more than 15 degrees is higher than that up to 15 degrees. The detailed analysis of rates of these items is given in DAR (Delhi Analysis of Rates). The difference in rates is on account of the extra labour for laying concrete on sloped surface. You can work out the unit rates for both the cases using your local market rates and find the extra cost involved (difference) for sloped roof, if you want to go by a recognized method.
The relevant pages of the DAR 2016 enclosed.
Analysis.pdf
 Filename:  Analysis.pdf
 Filesize:  84.6 KB
 Downloaded:  135 Time(s)
spsvasan
PostPosted: Mon Nov 12, 2018 1:45 am    Post subject: Re: change of roof (from flat to sloped) of a building Reply with quote
anurag.sinha wrote:
Dear Er.Anurag Sinha
In addition to the valuable information in the reference cited by Er.E.S.Jayakumar, the following may be considered
The contractor can also make a claim for the inclined shuttering which may require taller props and more labour
If the slope is larger than 30 degrees, top shuttering will become necessary to ensure good quality concrete and this can lead to further increase in costs
S.P.Srinivasan
sktrisal
PostPosted: Wed Nov 14, 2018 12:30 pm    Post subject: change of roof (from flat to sloped) of a building Reply with quote
I in 3 is around 20 degrees no need of double shuttering.Charge extra for sloping shuttering and concrete
On Wed, 14 Nov 2018, 16:26 spsvasan <forum@sefindia.org (forum@sefindia.org) wrote:
                  anurag.sinha wrote:                Dear All,
S.P.Srinivasan
