E value of TMT bar
predinesh
PostPosted: Thu Nov 08, 2018 7:16 am    Post subject: E value of TMT bar Reply with quote
An 8mm diameter TMT bar Fe 500D was tested for tensile strength with following results ,yield strength was 600N/mm2 ,ultimate tensile strength was more than 700N/mm2 ,elongation of 25 % ,but E value of 53 GPa.As design considers the E value of steel as 200GPa, this certainly has an implication in design.But why steel code IS 1786 is silent on this parameter. Or is this specimen a defective one as it is giving both high strength and high elongation.Kindly advice.
spsvasan
PostPosted: Sun Nov 11, 2018 11:59 pm    Post subject: Reply with quote
Dear SEFIAN
Yes, the abnormally low E value will have a significant effect resulting in larger defelction and larger crack widths
It is better to recheck the value using a different sample and, may be in a different laboratory also
If the low value is repeated, I think, you should take up this matter with the manufacturers and insist upon replacement of the entire lot
S.P.Srinivasan
dndhastak
PostPosted: Mon Nov 12, 2018 11:30 am    Post subject: E value of TMT bar Reply with quote
Test a few more samples from the same batch to confirmregards
On Mon, Nov 12, 2018 at 12:04 AM predinesh <forum@sefindia.org (forum@sefindia.org)> wrote:
sreekanth_pta
PostPosted: Tue Nov 13, 2018 2:30 pm    Post subject: E value of TMT bar Reply with quote
Can you please share the graph ploted to find out e value
On Mon, Nov 12, 2018, 12:03 AM predinesh <forum@sefindia.org (forum@sefindia.org) wrote:
SHIVA G
The maximum strain in steel should be greater than or equal to 0.002+((0.87*fy)/(Es)).Young's modulus of steel is inversely proportional to the strain value. If the E value decreases the strain value of the steel will increase.It might beneficial for us our structure with stand greater loads.
On 12 Nov 2018 12:04 a.m., "predinesh" <forum@sefindia.org (forum@sefindia.org)> wrote:
sktrisal
PostPosted: Wed Nov 14, 2018 12:30 pm    Post subject: E value of TMT bar Reply with quote
8mm steel can give elevated results try with 16mm and view the results
On Wed, 14 Nov 2018, 17:28 dndhastak <forum@sefindia.org (forum@sefindia.org) wrote:
[quote]            Test a few more samples from the same batch to confirmregards
On Mon, Nov 12, 2018 at 12:04 AM predinesh forum@sefindia.org (forum@sefindia.org))> wrote:
adroshan
PostPosted: Wed Nov 21, 2018 9:53 am    Post subject: Re: E value of TMT bar Reply with quote
Generally, during testing we get an elongated 'S' shaped curve. Initial part of curve will be flatter till full grip of jaws are mobilised. Subsequently the actual 'E' is reflected in the curve. In automated printouts from machine, this could become an issue. As another SEFIAN has already queried, what is the shape of the actual curve you got.
If the reason for the low 'E' value is indeed not this issue, then you should not use the rebar batch untill results from further testing is available to evaluate its conformance with acceptable values.
-Roshan A.D
