STAAD Pro COLUMN DESIGN
kunal_mohanty
PostPosted: Wed Nov 21, 2018 9:22 am    Post subject: STAAD Pro COLUMN DESIGN Reply with quote
Does STAAD Pro consider minimum eccentricity criteria as per is code 456 by default while designing column or additional parameter is required?
Whether design results shown by design tab such as Pu,Mux and Muy  in column members have considered minimum eccentricity or not?
kunal_mohanty
PostPosted: Thu Dec 13, 2018 9:32 am    Post subject: STAAD Pro COLUMN DESIGN Reply with quote
Please share your views on the topic.
Thank you
sukanta.adhikari
PostPosted: Thu Dec 13, 2018 9:55 am    Post subject: Re: STAAD Pro COLUMN DESIGN Reply with quote
Dear sir
Staad automatically considers the minimum eccentricity criteria for column design.
This you can check by giving track 2 command in design mode.
I have attached a snapshot of staad output which clearly shows that it includes min. eccentricity in column design
S Adhikari
 Filesize:  33.94 KB
 Viewed:  61 Time(s)
sakumar79
PostPosted: Fri Dec 14, 2018 3:39 am    Post subject: Reply with quote
Hi,
    I would like to add to Er Adhikari's reply - you have to remember that parameters for effective length factor, etc have to be set in order for STAAD to correctly calculate the additional moments. For example, if a column is restrained in one direction only in a floor, the effective length in the other direction is based on double storey height. However, STAAD will not take this automatically and has to be manually specified by the user.
Yours sincerely
S Arunkumar
kunal_mohanty
PostPosted: Wed Jan 09, 2019 7:01 am    Post subject: Re: STAAD Pro COLUMN DESIGN Reply with quote
[quote="sukanta.adhikari"]Dear sir
Thank you very much
kunal_mohanty
PostPosted: Wed Jan 09, 2019 7:03 am    Post subject: Reply with quote
[quote="sakumar79"]Dear Sir
Thank you.
