MAGIC PROGRAM FOR RCC COLUMN DESIGN (ALL CODES)
rg.gupta
PostPosted: Thu Nov 22, 2018 2:43 pm    Post subject: MAGIC PROGRAM FOR RCC COLUMN DESIGN (ALL CODES) Reply with quote
Dear SEFIANS
JAIHIND
The further delebrations and amendments in my previous article i.e. “ Magic equations for designing short RCC  columns of different shapes with axial,uniaxial & biaxial loads” published on page  57 to 60 of  INDIAN CONCREATE JOURNAL OCTOBER 2010
(copy enclosed as a ready reference) is nothing less than an invention/research in the field of Structural Engineering.
                The basic concept  used in the formation of these Excel Sheets are  not only limited to RCC column design for Indian code but also applicable to other Country’s Codes .This Concept is nothing but the beginning  of new era for research & development,  in the related fields. This is nothing but a tip of ice berg, requires
lot of scope of work for further Improvements/Development &Amendment.
1.     Due to  unavailability  of space expressed by the  ICJ ,they could neither published the full illustrations of other shapes of columns i.e. rectangular ,circular and L- Shape even parabolic &  ellipse  without any limitations nor they could arrange to provide the Excel Sheets  showing the formation of these Equations and  design of the columns for British Code & ACE Codes  as well.
2.     The solution of an example for column design is so tedius ,lengthy & very cumbersome as well as not on exact values but depending   by Designer’s judement  whereas the illustration shown by Excel Sheets Attached are so simple & give  results beyond anybody’ imagination within seconds. The results  are nothing   but the summation  of 2 Areas of reinforcements worked out on the basis of Area of steel for axially loaded column without  any eccentricity taken from different country’s codes and proportionate  Area of steel worked out for the excess  area of concrete worked out  without eccentricity.
     The Main Variables required in the formation of these Excel Sheets are, only  the values of fck , fy & “Equation of ultimate load  for axially loaded  column without Eccentricity from different Country’s Codes“
There  may be minor difference in the calculations of reinforcements worked out on the basic of these Excel Sheets if compared with the results of
other programs worked out on the basis of interactive curves prepared by trials.
The results are more Ethenthic because  the solution is based on first principals.  A lot of work is required to be done for further refinement
     & fine tuning.
The valuable  comments  are invited & shall be highly appreciated from every member of SEFI ,Structural Consultants ,Sciencetist and Renound Engineers.
Encl: Excel file & 4 Pages of ICJ
                                                          R.G.Gupta
Formar Supritending Engineer
Delhi Development Authority
Disc_Forum_Oct_2010_R.G.Gupta_ICJ_OCT_2010.pdf
 Filename:  Disc_Forum_Oct_2010_R.G.Gupta_ICJ_OCT_2010.pdf
 Filesize:  277.28 KB
 Downloaded:  708 Time(s)
page4.pdf
 Filename:  page4.pdf
 Filesize:  363.22 KB
 Downloaded:  180 Time(s)
Magic Program for RCC Column Design (all codes).xlsx
 Filename:  Magic Program for RCC Column Design (all codes).xlsx
 Filesize:  21.07 KB
 Downloaded:  799 Time(s)
hsrai
PostPosted: Thu Nov 22, 2018 5:06 pm    Post subject: Re: MAGIC PROGRAM FOR RCC COLUMN DESIGN (ALL CODES) Reply with quote
     & fine tuning.
Can you spell out what you wish to add more?
I (or many more fellow SEFIians) may wish to contribute, if you permit.
The attachments are not correct. 3 pages of ICJ has been replaced with same Excel file. That mean there is one page (no. 60 only) while 57, 58 and 59 are not there, while Excel is uploaded 4 time.
H.S.Rai
admin
Site Admin
Site Admin
PostPosted: Fri Nov 23, 2018 5:55 am    Post subject: Re: MAGIC PROGRAM FOR RCC COLUMN DESIGN (ALL CODES) Reply with quote
Dear Sir
We added the attachment from ICJ OCT 2010 issue to above post here.
Admin
hsrai wrote:
     & fine tuning.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
rg.gupta
PostPosted: Fri Nov 23, 2018 10:22 am    Post subject: MAGIC PROGRAM FOR RCC COLUMN DESIGN (ALL CODES) Reply with quote
Dear SEFIANS JAIHIND
The further delebrations and amendments in my previous article i.e. “ Magic equations for designing short RCC columns of different shapes with axial,uniaxial & biaxial loads” published on page 57 to 60 of INDIAN CONCREATE JOURNAL OCTOBER 2010 , is nothing less than an invention/research in the field of Structural Engineering. ICJ copy enclosed as a ready reference , download link and excel sheet download link and ICJ 2010 issue link https://icjonline.com/main_oct2010.htm where refer to bottom link saying "DISCUSSION FORUM: Magic equations for designing short RCC columns of different shapes with axial, uni-axial, bi-axial loads"
The basic concept used in the formation of these Excel Sheets are not only limited to RCC column design for Indian code but also applicable to other Country’s Codes .This Concept is nothing but the beginning of new era for research & development, in the related fields. This is nothing but a tip of ice berg, requires lot of scope of work for further Improvements/Development & Amendment.
There may be minor difference in the calculations of reinforcements worked out on the basic of these Excel Sheets if compared with the results of other programs worked out on the basis of interactive curves prepared by trials.
The results are more Ethenthic because the solution is based on first principals. A lot of work is required to be done for further refinement & fine tuning.
Encl: Excel file & 4 Pages of ICJ R.G.Gupta  Formar Supritending Engineer  Delhi Development Authority
 Filesize:  277.28 KB
 Downloaded:  114 Time(s)
Magic_Program_for_RCC_Column_Design_(all_codes).xlsx
 Filename:  Magic_Program_for_RCC_Column_Design_(all_codes).xlsx
 Filesize:  21.07 KB
 Downloaded:  131 Time(s)
kedar_kavathekar
PostPosted: Sat Nov 24, 2018 2:30 am    Post subject: MAGIC PROGRAM FOR RCC COLUMN DESIGN (ALL CODES) Reply with quote
Thanks for sharing
On 23-Nov-2018 3:57 PM, "rg.gupta" <forum@sefindia.org (forum@sefindia.org)> wrote:
hsrai
PostPosted: Sat Nov 24, 2018 10:06 am    Post subject: Re: MAGIC PROGRAM FOR RCC COLUMN DESIGN (ALL CODES) Reply with quote
Thank you
@Admin
Is it possible to merge different related topics (threads). I found there are more than 10 threads related to Magic Equation for Columns, like:
https://www.sefindia.org/forum/viewtopic.php?t=3646
If you change last number (after ?t=, which is 3646 in above example) with 3635, 3660, 3661, 4763, 4799, 4819, 5544, 8660, 8803, 19578, we find all are about the same topic. It would be better if, all can be merged.
In search, there are options:
Search topic title and message text
Search message text only
It will be nice, if we have:
Search topic title only
H.S.Rai
rg.gupta
PostPosted: Tue Dec 04, 2018 5:58 am    Post subject: Re: MAGIC PROGRAM FOR RCC COLUMN DESIGN (ALL CODES) Reply with quote
Thanks for adding 3 pages of ICJ in my above said posting
It is further clarified that a confusion is being created to be nothing new
Where as  previously  it was an Article only but  now it is a Resarch work
inventing  a new concept  for design of RCC Column.  demonstrated through
Modified Excel Sheets (attached) for more circulation & comments.
Although   my posting dated 23/11/2018 was visited by more than
600 SEFIan’s till date but no one  has commented on my original work done
through Excel program file which is Unique in nature with a new concept ever
thought before by any intelectuals in the field . Sorry that ,out of hundreds of
SEFIan’s No one has taken my posting seriously. Otherwise  thousands of
comments have received till now. Because the RCC column design with
uni-axial, bi-axial moments is so tedius.lengthy ,time consuming & lot of
approximations using charts & graphs etc also Getting different results from
different Softwares.
Magic Program for RCC Column Design (all codes)R.xlsx
 Filename:  Magic Program for RCC Column Design (all codes)R.xlsx
 Filesize:  25 KB
 Downloaded:  81 Time(s)
