Splice design in bridges
arunkumar.mgs
PostPosted: Wed Jan 30, 2019 6:21 pm    Post subject: Splice design in bridges Reply with quote
Respected members,
Splices in bridge flexural members are required to be designed for greater of 1.1 times actual loads or 80% capacity of the member as per IRC 24. AASHTO specification also requires minimum 75% capacity of the member in a splice.
1) If a section much larger than that required for ultimate design loads is provided (due to other functional requirements) is it still required to design the splice for % of section capacity?
2) Do splices cause stiffness reduction in the structure (not accounted for in analysis) if designed for actual loads and not minimum section capacity?
3) For a moment splice in a member should distance for forces in extreme bolt be taken from center of splice or center of bolt group on each side of splice? (Please refer attached sketch).
Please share your views.
Thank you,
Arunkumar.G
 Filesize:  260.14 KB
 Viewed:  63 Time(s)
umarfarookhmomin@gmail.co
PostPosted: Thu Feb 28, 2019 1:21 pm    Post subject: Re: Splice design in bridges Reply with quote
Hello,
can you mention the the AASHTO clause number as well IRC 24.
arunkumar.mgs wrote:
Respected members,
Thank you,
Arunkumar.G
