hydraulic steel gate
santosh1
PostPosted: Tue Mar 26, 2019 5:30 am    Post subject: hydraulic steel gate Reply with quote
Dear all,
I am going through the design of hydraulic steel draft tube gate for power house. i calculated the loading diagram and  located the position of horizontal girders and gate leaf plan etc.
For sizing the girders, i came across the problem on solving the problems by moment distribution methods (many prefer this methods).But i am quite in doubt in using this methods.
I have attached my diagrams.
Kindly suggest me the way i should approach to solve this.
Santosh
Moment distribution methods
 Filesize:  1.24 MB
 Viewed:  70 Time(s)
abhio
PostPosted: Tue Mar 26, 2019 10:24 am    Post subject: Reply with quote
Dear Er Santosh,
Moment distribution is quite simple, but would take a lot of steps (with consequent loss of accuracy) for multiple spans. I'd not do it today for more than 3 spans. Why not use a frame analysis program like STAAD / SAP instead?
santosh1
PostPosted: Tue Mar 26, 2019 11:37 am    Post subject: Reply with quote
Dear abhio,
Thanks for the suggestion.
But have only 3 girders in the gate frame and for sizing i need to solve this to get the load on positioned girders.
the manual calculations much be appreciated.
Thnanks
santosh
abhio
PostPosted: Tue Mar 26, 2019 1:54 pm    Post subject: Reply with quote
Dear Er Santosh,
Please find attached a simple spreadsheet for moment distribution for your structure.
A S Oundhakar
moment distribution.xlsx
 Filename:  moment distribution.xlsx
 Filesize:  17.66 KB
 Downloaded:  121 Time(s)
santosh1
PostPosted: Mon Apr 22, 2019 11:19 am    Post subject: Steel gate Reply with quote
HEllo Abhio,
Thanks for the sheet.
How do you calculate the shear force due to moments and due to loads for the proposed loading ?
Kindly suggest the formulas to use or methodology .
thanks and regards
Santosh
abhio
PostPosted: Mon Apr 22, 2019 2:32 pm    Post subject: Reply with quote
Dear Er Santosh,
Having found the end moments and reactions, you can find shear force and bending moment at any point by taking free body diagrams of each beam separately. Please refer to any analysis textbook.
A S Oundhakar
santosh1
PostPosted: Fri Aug 09, 2019 10:26 am    Post subject: steel gates Reply with quote
Hello Abhio,
Thank you for the sheet. But as i was working on it, i got confused on your triangular load to left values. Kindly give the formula you have worked on for it.
Hope the loading is of (ton/m).
Santosh
abhio
PostPosted: Wed Aug 14, 2019 5:59 am    Post subject: Reply with quote
Dear Er Santosh,
"Triangular load to the left" means load with maximum value towards the left. Please refer to any standard book for fixed end moment values for this case.
The spreadsheet is not based on any particular units, so the output moments will be in the same units as the inputs. If you give length and loads in m and tonne units, the BM will be in t.m. If you give the inputs in feet and kips, you'll get BM in kip-ft.
A S Oundhakar
