Long term deflection calculation sheet.
amandeep verma
PostPosted: Wed May 08, 2019 1:49 pm    Post subject: Long term deflection calculation sheet. Reply with quote
One way portal frame is analysed for long term deflections. Columns are 750*900mm and 24 m apart c/c and column height from foundation is 9m and beam size is 600mm X 1287.5 mm including 5'' slab. Bay width is 4.6m and There is no upper storey only Live load of 1.5KN/m^2 is considered and Tile terracing load is considered.
Long term deflections are coming 89 mm and permissible deflections is 96mm (L/250). References taken from Purshottham Book and M.L.Gambhir and IS 456, SP16. Edges of beams are considered as fixed.
Check sheet and draft and give your valuable advices.
Amandeep Verma.
Long Term Deflection.xlsx
 Filename:  Long Term Deflection.xlsx
 Filesize:  12.44 KB
 Downloaded:  65 Time(s)
