Reg. blast load definition in staad pro
kanchin639@gmail.com
PostPosted: Sat Oct 06, 2018 4:41 pm    Post subject: Reg. blast load definition in staad pro Reply with quote
Hello everyone,
I am working on Dynamic Behaviour of Buildings subjected to blast loads.
i have calculated the parameters using IS 4991,
i would want to know how the blast forces are assigned in Staad Pro, to study the responses.
i have an idea that it is assigned by force Time history analysis.
Can you'll please help me in that regard??
i am interested in studying the responses like displacements, drift , velocity and acceleration.
i have attached the staad file as well as the calculation of the loads.
thank you Smile
30m (STAND OFF DIST) 6S R.xlsx
excel sheet of calculation
 Filename:  30m (STAND OFF DIST) 6S R.xlsx
 Filesize:  41.11 KB
 Downloaded:  150 Time(s)
abhio
PostPosted: Thu Oct 11, 2018 7:18 am    Post subject: Reply with quote
Dear Er Kanchin,
Unfortunately, STAAD does not allow time history on pressure/ distributed loads, only point loads. Hence, you have to provide point loads with defined time histories. Finally, apply the load with the "Time load" command, and perform analysis.
PostPosted: Thu Oct 11, 2018 3:52 pm    Post subject: Reg. blast load definition in staad pro Reply with quote
abhio wrote:
Dear Er Kanchin,
Thank you very much sir!
can i know why in time-history analysis: in time history load case self weight and other applied loads are taken positive in all directions?
why is it important?
Saeed.naoum92
PostPosted: Sun May 19, 2019 10:20 am    Post subject: Reply with quote
Hello Everyone
i am interested in blast load and how to apply it on a structure, i am now studying the effect of it on a an RC Framed Building, i have already calculated the blast parameters of a 100 kg TNT Charge Weight and 30 m Stand-off Distance and i converted the pressure into Nodal Force.
I am using Csi Etabs software but i encountered a problem in defining the Time History load case, if anyone could help me with that matter i would be so appreciated.
promoocodes
PostPosted: Mon May 20, 2019 12:34 pm    Post subject: Active Target Coupon Codes Reply with quote
Hello everyone, I was trying to be a member of this forum to grab some knowledgeable stuff offered by the forum and also want share some useful things to this, Active Target Coupons and now In one of the member of it feeling great.
