Basics of Earthquake analysis
patoliyanirav@gmail.com
PostPosted: Mon Jun 10, 2019 8:25 am    Post subject: Basics of Earthquake analysis Reply with quote
Analysis method for calculation of earthquake load is highly depend on medium in which structure is situated and medium contain by structures kipping other factor constant.
Followings are basic cases for the same.
Case-1: Ground supported foundation with supper structure is above ground and contain only
atmospheric air.
Case-2: Ground supported foundation with supper structure is above ground and contain only
non pressure liquid /water.
Case-3: Ground supported foundation with supper structure is above ground and contain only
soil.
Case-4: Under liquid / water structure and contain only atmospheric air.
Case-5: Under liquid / water structure and contain only non pressure liquid /water.
Case-6: Under liquid / water structure and contain only soil.
Case-7: Underground structure and contain only atmospheric air.
Case-8: Underground structure and contain only non pressure liquid /water.
Case-9: Underground structure and contain only soil.
I would like to start discussion on which clauses are applicable for the above mentioned cases from IS:1983 and IRC-6.
